Message 1 of 18
Infinity Upload Speed suddenly dropped
Hi,
After having an upload speed on infinity of between 6mb and 7mb since is it was installed, it has suddenly dropped to 1mb. It has been faulted with BT via the speedtester but that has come back saying fixed, but it is not.
My BT Hub6 gives me:
Capture.PNGand my ASUS Router:
Capture.JPGBT Speed checker gives:
But according to BT Checker I should get the following:
Why am I not and why will BT not do anything about it? 1mb is all but unusable for uploading data, I could get a faster speed on ADSL!!
Regards,
Stephen Ord
17 REPLIES 17
Message 2 of 18
Re: Infinity Upload Speed suddenly dropped
Firstly, you wouldn't get a faster upload on ADSL.
Have you tried dialling 17070 from your landline and running the quiet line test?
Message 3 of 18
Hi,
Yes, I've done a quiet line test and that seems OK. Have also plugged direct into my master socket via a filter and that gave the same results, although not sure how long I would have to leave it for it to make any difference. Couldn't leave it for too long as it left the rest of the house without a phone.
Regards,
Stephen
P.S had my tongue in cheek with the ADSL comment. Smiley Happy
Message 4 of 18
If the sync speed doesn't increase in the test socket, you need an engineer. Simple as that.
Message 5 of 18
Thanks Webby, how do I get an engineer as BT have closed the fault saying 1mb is OK?
Stephen
Message 6 of 18
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
You will probably be expected to plug a BT Home hub in, as BT do not support other routers, as it may be a router incompatibility.
Message 7 of 18
Thank you, can put my HomeHub6 back on in about 30 seconds!
Stephen
Message 8 of 18
Stephen
It would be worth trying, to prove the issue, as you are likely to be asked about it.
Post the info from this link.
http://192.168.1.254/0000012803/gui/#/technicalLog/information
Internal wiring can also affect upload performance.
I know you said you had tried the master socket, but could you try connecting things up like this.
Moderator
Moderator
Message 9 of 18
@StephenOrd Please use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username.
Neil
Message 10 of 18
Hi,
Sorry if I wasn't clear but that's exactly what I did with the master socket.
Here's the log:
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084316+NQ61201374
Firmware version:
SG4B10002244
Firmware updated:
27-Jan-2017
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
0 Days, 0 Hours 7 Minutes 11 Seconds
Data rate:
1.22 kbps / 33.59 kbps
Maximum data rate:
1215 / 38461
Noise margin:
6.3 / 6.2
Line attenuation:
24.5
Signal attenuation:
0 / 245
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
9 MB Uploaded / 11 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-5PQX
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-5PQX
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
90:72:82:94:53:EB
Software variant:
Boot loader:
7.33.1
