Bc1973
Message 1 of 5
Infinity, Vision and Airport Extreme
Hi all. I've managed to get my Airport Extreme up and running in unison with Infinity but I still have the Home Hub 3 plugged in (with wireless turned off) so that I can run BT Vision. Is there a way I can use the Airport to run Vision and remove the Home Hub entirely?
I tried simply plugging the OpenReach modem directly into the Airport but that didn't work. I'd imagine I need to monkey around with some settings but, not being technically minded, I have no idea how to do that.
Tags (2)
4 REPLIES 4
jjgraphics
Recognised Expert
Message 2 of 5
Re: Infinity, Vision and Airport Extreme
Hi, long time Mac user here.
1   Get rid of the HH3
2   Connect the AE to the OpenReach Modem via its WAN port.
3   Set up the AE.
4   Connect the Vision box to the AE in the same way you currently do with the HH3, ie: Ethernet cable or PowerLine adaptors.
"It just works!"
(Well, it does for me and the WiFi is stunningly better than the HH3).
Bc1973
Message 3 of 5
Yeah, that's what I tried but the BT vision box ceased connecting. I may give it another go. Is there a 'special' way to set up the Airport?
jjgraphics
Recognised Expert
Message 4 of 5
You may have to reboot the vision box so it re-acquires an Ethernet address from the DHCP server in the AE.
Bc1973
Message 5 of 5
I'll give that a go tonight.
