Message 1 of 5
Infinity Wiring
Needed to ease the box from the wall for decorating purposes and and its a right muddle inside, some wires taped back, others hanging loose. Thought I would post to see if anyone can confirm that all looks in order. Essentially it seems that two wires do the lot.
4 REPLIES 4
Message 2 of 5
Re: Infinity Wiring
if everything is working ok then just leave it alone
Message 3 of 5
Re: Infinity Wiring
if you are not having problems then I would leave it but strange with 3 white cable coming into master socket but ano=ly connection really visible is that to main points A&B
Message 4 of 5
Re: Infinity Wiring
Looks fine to me, the other cables look like extensions that have been disconnected. Broadband and phones only need 2 wires.
Message 5 of 5
Re: Infinity Wiring
OK, thanks all. No problems and no intention of messing with it, just thought I would post, I was bit worried that I might have accidentally sprung a couple of wires from a connector or something.
Thanks again.
T
