bpalmf
Message 1 of 4
Infinity and wiring to Vision box
Hi
Getting infinity on Monday. The main socket is updairs.as is pc. Will they run ethernat cable to Vision bos downstairs or do i have to use power adapters??
thanks
bpalmf
3 REPLIES 3
Message 2 of 4
Re: Infinity and wiring to Vision box
power lines are the best answer for vision how are you connecting at the moment ?
bpalmf
Message 3 of 4
with power lines thought wired connection would be faster but thanks for the help
Message 4 of 4
power-lines are more than adequate for vision it does not need a great amount of speed providing it is 2mb or over
