Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Does anyone know how long I have to wait? Friends in the Chippenham area already have it but when I do the landline check it says it is not available. We currently have the Total Broadband full package.
I've tried the test mentioned in the sticky and it doesn't say anything about my line supporting fibre optic technology.
Solved! Go to Solution.
Hi John, Just tried it and the map key had a green accepting orders marker. Under the Exchanges already accepting orders, Chippenham is marked as available. Does this mean I can get it then, and if so who should I call?
Go HERE and enter your phone number to see if it's available to you.
Not all cabinets are enabled before the exchange starts accepting orders.
Hi, I did as suggested and received this:
Your exchange is ADSL enabled, and our initial test on your line indicates that your line should be able to have an ADSL broadband service that provides a fixed line speed up to 2Mbps.
Our test also indicates that your line currently supports an estimated ADSL Max broadband line speed of 4Mbps; typically the line speed would range between 3Mbps and 5Mbps.
Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 5.5Mbps; typically the line speed would range between 4.5Mbps and 6.5Mbps. Our test also indicates that your line could support an estimated ADSL 2+ Annex-M broadband upstream line speed of 1Mbps and downstream line speed of 5.5Mbps; typically the downstream speed would range between 4.5Mbps and 6.5Mbps.
Is it just a case of waiting until it is enabled then? I assume BT are still opening it up to new areas.
