lydanial
Message 1 of 15
Infinity below 2mb down
Hi guys... Went onto infinity last year and aprt from a few hiccups I have been getting a stable 24mb down.
Since about 5pm yesterday it has dropped below 10mb and keeps dropping. currently I am below 2 mb and the film I was enjoying streaming has died a death.
I have run the whole sale test and that got 2.2, then when I logged in under the bt requested user name I actually recorded 0 down and 5 up.
Whats going on?
Tags (1)
14 REPLIES 14
Webby
Message 2 of 15
Re: Infinity below 2mb down
Wired or wireless?
Are you using a home hub 5? If so could you log into the hub via 192.168.1.254 and post the line stats (connection speed, snr, attenuation etc).
john46
Message 3 of 15
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
if you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
lydanial
Message 4 of 15
Information for Helpdesk agents
When contacting the BT Broadband helpdesk, the agent might ask you for details about your BT Home Hub. This page contains all of the information they are likely to request.
1. Product name:BT Home Hub
2. Serial number:+068543+NQ51320658
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 10/07/154. Board version:BT Hub 5A
5. DSL uptime:0 days, 00:39:38
6. Data rate:6041 / 26211
7. Maximum data rate:6041 / 40278
8. Noise margin:6.1 / 12.6
9. Line attenuation:34.8 / 22.2
10. Signal attenuation:47.4 / 19.8
11. Data sent/received:60.5 MB / 150.0 MB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:No
14. 2.4 GHz Wireless network/SSID:SuckMyFibre
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:5G Fibre
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:00:37:b7:23:48:9e
24. Modulation:G.993.2 Annex B
25. Software variant:AA26. Boot loader:1.0.0
lydanial
Message 5 of 15
lydanial
Message 6 of 15
This is the one done on the server three test after i changed the settings on my router.
lydanial
Message 7 of 15
lydanial
Message 8 of 15
These tests were done on my wired pc just for your information .
lydanial
Message 9 of 15
I have just ran another test and I'm now getting 0.5mb now.
I can barely open webpages with all the pictures and things.
lydanial
Message 10 of 15
Good morning...
Speed is currently 0.5 down and 5.5 up
Who do i need to contact to report this?
