MBR123
Expert
Message 1 of 8
Infinity connection gone wrong 2hrs. later after ordering the new HH4?.
Hi,
I am having serious issues at the moment. I ordererd the new HH4 about 4.30p.m. today and now it seems my Infinity connection has gone mad!. I have tried to restart my equipment a few times but no difference, also every time I restart the equipment it gives me an unusual IP address that starts with 109. instead of the 86., it normally gives but I cannot get it back. I have never had issues like this until now. Has it got something to do with ordering the new Home Hub 4 which arrives this Thursday?:-
Please click on white star to the left and say thanks if I have helped you at all!. 🙂 Thank you. Some handy links Copy & Paste:-
http://bthomehub.home/
http://netalyzr.icsi.berkeley.edu/index.html
http://diagnostics.bt.com/login/?workflow=Speed
7 REPLIES 7
Message 2 of 8
Re: Infinity connection gone wrong 2hrs. later after ordering the new HH4?.
not related to the new hub have you tried a single modem restart then one hub restart that may solve the IP Address
MBR123
Expert
Message 3 of 8
Hi John, thanks for the reply,
I have done a restart on the Openreach box (hold in for 5 seconds), turn on and off and done a normal retstart on the HH3 as well (several times). The new IP addresses are all over the place and I think this is the problem, it never comes up with 86. anymore, it always now either 109., 81., 80., and so on. 😞 Getting very frustrating!. Everything was fine I did a recent check before ordering the HH4 but after about a couple of hrs., so on ordering the new HH4, it started doing it.
Distinguished Expert
Message 4 of 8
Why does it matter what the IP address begins with, 109, 81, 80, 86 ?
To say thanks for a helpful answer, please click the white star
MBR123
Expert
Message 5 of 8
Just done a restart and its back to normal now all green on disagnostic check, the IP now starts with 81., but works OK!. Weird, something must of been a foot!. 🙂
@legitimise_sailing. If your IP address does not start with 86., it means there is a problem somewhere down the line. Usually when mine starts with anything other than 86.,in my area code, it gives me a problem with my Infinity connection. I dont know why?, but it does!. 😉
Guru
Message 6 of 8
My IP address often starts 86. and often not. I haven't noticed any problems when it isn't. (Currently 31.)
Message 7 of 8
like wise makes no difference to the connection what ever the IP address is
soapy
Expert
Message 8 of 8
it does not matter what the ip address starts with, they are all blocks of ips that are assigned to bt to use, i sometimes get an 86 , other times 31 or 109, it makes no difference
