smartie
Message 1 of 5
Infinity install question
Hi,
So the engineer is booked for next thursday the 3rd & I'm wondering if it's ok just to set up the hh3 myself when it arrives instead of leaving it for him to do, as in putting it where I want it which will be very close to the master socket & connecting the power cable & ethernet cable from the hh3 to my solwise homeplug which I'll be using to send the connection around the house. I don't see the point in leaving it for the engineer to do when I could do it myself.
4 REPLIES 4
Webby
Message 2 of 5
Re: Infinity install question
Leave it for the engineer mate. No point plugging it in and wasting power till the Openreach modem is in. I guess you could connect it to your home plugs with the Ethernet cable but you may as well just do that once he's gone.
dcullum
Message 3 of 5
I set mine up before the service went live as I had a quite complicated port forwarding setup and I didnt want to cause any disruption to my services when the service went live. In my case I was also changing the IP addres of the device, and while this had no practical consequences, it did mean that the FOn service never went live on my box, even after I activated it online. This was actually a blessing to me, but would depend on yor perspective!
smartie
Message 4 of 5
One more thing, I have 3 slave sockets in the house which are connected to the master socket, i.e when using the test socket in the past to diagnose adsl issues all the slave sockets are disconnected, do these slave sockets still need to have dsl filters connected to them?
john46
Message 5 of 5
once the engineer has fitted the new faceplate to your master socket no they do not need filters
