chester
Message 1 of 9
Infinity installation
We will soon be upgrading to BT Infinity
The master socket is in a different room to our current router & moving the computer to the master socket is not viable.
Will the Bt Engineer be able to move the master socket to a different location?
Using will be possible by difficult or is a powerline adaptor kit an option?
8 REPLIES 8
Message 2 of 9
Re: Infinity installation
If you get a BT Engineer they will generally move your master socket without problem however if you get a contractor the will generally refuse to move the master socket.
You could use powerline adaptors or better if you can use a data extension kit which the engineer should have with him. You could also use Ethernet cable to connect your computer to the hub.
chester
Message 3 of 9
Thanks Guru
We do'nt really want to use the extension kit because it would mean quite a lot of cable tacked to the top of the skirting board so powerline seems a better bet.
I thought that with powerline a cable connected the computer to the powerline adaptor - or am I wrong?
Message 4 of 9
There are plenty of solutions offered by BT.
BT Connected Home Range of devices to extend broadband
chester
Message 5 of 9
Thanks Keith
Do you happen to know if the engineer carries anything more than an extension kit or do I need to go shopping first!
Message 6 of 9
@chester wrote:
Thanks Keith
As far as I am aware, they just carry an extension kit, but others may know more.
At least with the BT solutions, you can extend your broadband to wherever you want, and move it later, without messing around with extra wiring.
chester
Message 7 of 9
Thanks again
I will contact the BT Shop tomorrow
Sage
Message 8 of 9
@gg & Keith, why are you advising people to accept an inferior install and spen money on powerline adaprtors?
From the BT site, "The engineer may install a small data extension kit and some extension cabling within your home if needed to make sure your equipment gives you the fastest possible speed."
LINK
If the contractor refuses to do this then let him install and call BT for a BT engineer to remedy the dodgy install.
Message 9 of 9
@pippincp wrote:
@GG & Keith, why are you advising people to accept an inferior install and spen money on powerline adaprtors?
LINK
It's not advising to accept an inferior install, it's called answering the OP's question and giving him options!
