hazelst3
Message 1 of 8
Infinity is how long it will take to sort out a fault!
Up  to 40 Meg? Don't be fooled.
http://www.speedtest.net/result/1869307650.png
7 REPLIES 7
Distinguished Expert
Message 2 of 8
Re: Infinity is how long it will take to sort out a fault!
I first raised the fault on 9 March 2012. It's been closed several times by BT "we think it's fixed", but I've had to reopen it. It's open right now.
Message 3 of 8
Have either of you contacted the moderators on here?
Message 4 of 8
Yes. No reply.
hazelst3
Message 5 of 8
Contacting anybody at BT is easy, getting them to sort out a fault is completely different!
Message 6 of 8
When did you contact the mode Bullitt. If it's longer than 72 hours since you've sent it in I'd suggest resending it.
Hazel - the mods on here have a very very good reputation of solving issues.
Message 7 of 8
India just called. She thinks the engineers think it's fixed. She'll call me back tomorrow night to see if it is.
Message 8 of 8
well if you have had a call from India that is not a contact from the mods as they are UK based as webby has said contact them again this is a link to them
http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone directly to you within 3 working days
They are a UK based BT specialist team who have a good record at getting problems solved
