legitimise_sailing
Distinguished Expert
Message 31 of 41
Re: Infinity is slow, especially wireless
Have you tried it without the homehub?
To say thanks for a helpful answer, please click the white star
Ninjoid
Message 32 of 41
How do I do that please?  Thanks
It's ok...worked it out...ta
Speed at 9:55am same through direct connection as through the hub...interesting to see what gives when speed does drop and I try this.
Ninjoid
Message 33 of 41
Slowdown has kicked in again after lunch.....have tried it with a wired connection from my modem to my pc with the same result....meaning the HH3 is ok.
Dramatic drop from 32-34Mb in the morning to around 6-10Mb this afternoon....upload speed unchanged and isn't an issue.
Ninjoid
Message 34 of 41
Engineer due tomorrow afternoon....speed has been down all afternoon and evening....off to bed now and we've hit just over 2Mb download.
IP profile is 34.41Mbps.
Will let the mods know how it goes..had a mail from BT (Chris) this afternoon so will mail back once engineer has been.
Tags (1)
Ninjoid
Message 35 of 41
Latest position:
Engineer called this afternoon and all tested out ok into our house.  So he went to the exchange to run a few more tests.  Was gone over an hour and came back to say that there were issues with the cabling for our connection so he has stripped back the cabling and put new connections in place.
He did say that our IP profile would be reset - currently we are at 35.73Mps and the speed is acceptable currently at 5pm, though I will be checking throughout the evening and forthcoming days....I'm not seeing speeds as low as 3Mb as before...but that could still be to come.
Because of the IP reset he said we would have to wait the obligatory 10 days for the line to stabilise....hopefully the IP reset won't result in reduced speed.
Will let you know how it goes over the coming days.
Ninjoid
Message 36 of 41
.....and the speed has gradually been reducing since 5:30pm.....if the engineer found no faults line wise then this has to be network congestion, hasn't it?  I appreciate the speed may fluctuate during the 10 day period following IP reset but the pattern here is plain to see....ok during the day but evening time when people are home and using their connections our speed drops....
Can anything be done about network congestion?
ironman123
Recognised Expert
Message 37 of 41
Not without stopping BT Sport Ninjoid,but that is very unlikely.:)
legitimise_sailing
Message 38 of 41
It's often congestion at the gateway you connect to - the hop after your router on a trace route.
ironman123
Recognised Expert
Message 39 of 41
Yep, agreed legitimise_sailing, the gateway is the most critical point on the network.
Ninjoid
Message 40 of 41
Update 22/10...probably tempting fate but so far as at 8pm we've had no drop in speed...wired at 33-35Mb....probs spoke too soon now!
