judas90
Message 1 of 19
Infinity issue - websites will not load!!
Hello
I have had an issue since sunday 27th April. I cannot load any websites whatsoever. I have tried from two different laptops, ipods, and iphones all with same issue. I have reset homehub4 to factory defaults. reloaded hub and openreach box, done netsh int ip reset, netsh winsock reload catalog, changed DNS to public DNS servers, everything to no avail.
BT say everything looks fine. My laptop says i'm coneccted to the internet, and I can even ping websites. One thing i have noticed though is i cannot tracert to any, as it doesnt get past the first hop (hub).
I can't think of anything else to try except cancel BT and go back to Sky...
Any help would be great as BT are denying anything is wrong.
Also tried both wireless and on the wire...
Matt
18 REPLIES 18
pippincp
Sage
Message 2 of 19
Re: Infinity issue - websites will not load!!
Try a direct connection to the modem .
Step 1: Remove the homehub from the modem
Step2: Connect your pc/laptop into the modem using LAN1 port (LAN2 is disabled and not in use)
Step3: Open network and sharing centre on windows and click set up a new connection or network
Step4:  Connect to the internet (the top option) then click make a new connection Broadband PPPoE
Step5:  Username Internet@btbroadband.com and the password as broadband
Step6: connect, for some reason it may say that it cannot connect, just keep pressing try again if this happens and it will eventually connect.
judas90
Message 3 of 19
Also, one email i received from BT said I had an issue with my IP profile, but still not had a call from the network team regarding this...
judas90
Message 4 of 19
Hi Pippincp
I have just tried that, but got the same thing. Can ping out, but nothing will load...
thanks
Matt
PPP adapter Broadband Connection:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Broadband Connection
   Physical Address. . . . . . . . . :
   DHCP Enabled. . . . . . . . . . . : No
   Autoconfiguration Enabled . . . . : Yes
   IPv4 Address. . . . . . . . . . . : 81.151.162.164(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.255
   Default Gateway . . . . . . . . . : 0.0.0.0
   DNS Servers . . . . . . . . . . . : 213.120.234.42
                                       194.74.65.69
   NetBIOS over Tcpip. . . . . . . . : Disabled
C:\Users\admin.matt>ping www.bbc.co.uk
Pinging www.bbc.net.uk [212.58.244.67] with 32 bytes of data:
Reply from 212.58.244.67: bytes=32 time=26ms TTL=51
Ping statistics for 212.58.244.67:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 26ms, Maximum = 26ms, Average = 26ms
C:\Users\admin.matt>nslookup www.redcafe.net
Server:  indnsc92.ukcore.bt.net
Address:  213.120.234.42
Non-authoritative answer:
DNS request timed out.
    timeout was 2 seconds.
Address:  193.27.1.42
pippincp
Sage
Message 5 of 19
Look at you default gateway.
legitimise_sailing
Distinguished Expert
Message 6 of 19
Why aren't you using DHCP?
To say thanks for a helpful answer, please click the white star
judas90
Message 7 of 19
I just did what was suggested, do you get a DHCP address when connected directly to white modem? What should gateway be?
thanks
legitimise_sailing
Message 8 of 19
The gateway is assigned by DHCP as are the DNS servers and the IP address. Did you hard-code these?
judas90
Message 9 of 19
Well, wasn't sure if the openreach box gave out DHCP addresses? Thought that was what the home hub was meant to do?
Didnt hard code anything, and got DNS servers etc. Could ping out, as in the output...
That output was from when directly connected to the white openreach box...
Will try again, and try with DHCP.
judas90
Message 10 of 19
Hi
It was set up for DHCP, still nothing. here is some outputs when connected directly into white openreach box:
   IPv4 Address. . . . . . . . . . . : 86.166.130.121(Preferred)
                                       194.74.65.69
Wireless LAN adapter Wireless Network Connection:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . : home
   Description . . . . . . . . . . . : Intel(R) Centrino(R) Advanced-N 6200 AGN
   Physical Address. . . . . . . . . : 58-94-6B-09-B7-18
   DHCP Enabled. . . . . . . . . . . : Yes
Ethernet adapter Local Area Connection:
   Description . . . . . . . . . . . : Intel(R) 82577LM Gigabit Network Connecti
on
   Physical Address. . . . . . . . . : 68-B5-99-F2-BB-16
   Link-local IPv6 Address . . . . . : fe80::81ed:60c7:6f31:fe28%11(Preferred)
   Autoconfiguration IPv4 Address. . : 169.254.254.40(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.0.0
   DHCPv6 IAID . . . . . . . . . . . : 241743257
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-17-D8-E6-E9-68-B5-99-F2-BB-16
   DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
   NetBIOS over Tcpip. . . . . . . . : Enabled
 C:\Users\admin.matt>ping 8.8.8.8
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 8.8.8.8: bytes=32 time=31ms TTL=45
Ping statistics for 8.8.8.8:
    Minimum = 31ms, Maximum = 31ms, Average = 31ms
C:\Users\admin.matt>tracert 8.8.8.8
Tracing route to 8.8.8.8 over a maximum of 30 hops
  1    17 ms    17 ms    16 ms  217.32.142.4
  2     *        *        *     Request timed out.
  3    17 ms    17 ms    18 ms  host109-159-245-138.range109-159.btcentralplus.c
om [109.159.245.138]
  4    17 ms    17 ms    17 ms  31.55.165.215
  5    17 ms    17 ms    17 ms  31.55.165.109
  6     *        *        *     Request timed out.
  7    29 ms    31 ms    30 ms  109.159.250.174
  8     *        *        *     Request timed out.
  9     *        *        *     Request timed out.
 10     *        *        *     Request timed out.
 11     *        *        *     Request timed out.
 12     *        *        *     Request timed out.
 13     *        *     ^C
