legitimise_sailing
Distinguished Expert
Message 11 of 19
Re: Infinity issue - websites will not load!!
Odd. What do these settings look like when you have the Homehub connected as normal?
To say thanks for a helpful answer, please click the white star
judas90
Message 12 of 19
Wireless LAN adapter Wireless Network Connection: Connection-specific DNS Suffix . : home Description . . . . . . . . . . . : Intel(R) Centrino(R) Advanced-N 6200 AGN Physical Address. . . . . . . . . : 58-94-6B-09-B7-18 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv4 Address. . . . . . . . . . . : 192.168.1.65(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : 30 April 2014 22:41:27 Lease Expires . . . . . . . . . . : 01 May 2014 23:01:41 Default Gateway . . . . . . . . . : 192.168.1.254 DHCP Server . . . . . . . . . . . : 192.168.1.254 DNS Servers . . . . . . . . . . . : 192.168.1.254 NetBIOS over Tcpip. . . . . . . . : Enabled C:\Users\admin.matt>ping 8.8.8.8 Pinging 8.8.8.8 with 32 bytes of data: Reply from 8.8.8.8: bytes=32 time=38ms TTL=44 Reply from 8.8.8.8: bytes=32 time=35ms TTL=44 Reply from 8.8.8.8: bytes=32 time=128ms TTL=44 Reply from 8.8.8.8: bytes=32 time=122ms TTL=44 Ping statistics for 8.8.8.8: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 35ms, Maximum = 128ms, Average = 80ms C:\Users\admin.matt>Tracert 8.8.8.8 Tracing route to 8.8.8.8 over a maximum of 30 hops 1 2 ms 1 ms 1 ms BThomehub.home [192.168.1.254] 2 * * * Request timed out. 3 * * * Request timed out. 4 * * ^C C:\Users\admin.matt>
judas90
Message 13 of 19
  4     *        *     ^C
legitimise_sailing
Message 14 of 19
I think the OR modem is broken. Did you try a factory reset on it? ya know hold the reset button on the back of the modem for 15 seconds (long time) & let it reset to see if that corrects it?
judas90
Message 15 of 19
Hi
Just tried it...nothing. Some kind of routing issue on BT network I'm thinking. The support has been terrible! Useless...if its not determined what the issue is tomorrow, I'm cancelling and going back to sky i think.
Unless I've been capped, but i've been assured thats not the case, as they just bill you on excessive use...
pippincp
Sage
Message 16 of 19
I'm inclined to agree with l_s your modem is borked.
Easiest way tro get a replacement is to unplug the modem, ring in and tell them there's no lights on and you've no connection. Obviously don't tell them it's unplugged. If theyinsist on going thrugh the script - pretend to do it.
judas90
Message 17 of 19
Spoke to BT again this morning, and they are sending out a new Hub...not sure this will help, as we think its the modem. He said they don't send out modems unless the lights are not on...so will follow your advice after I've tried the hub.
thanks
Matt
pauljm
Message 18 of 19
Hi
Any further news on this situation?
I have had similar problems & BT sent a new Hub but I still get intermittent problems with web pages not loading -- on 4 different computers!
ray_dorset
Distinguished Guru
Message 19 of 19
Try changing your DNS servers on the PC to use Google - 8.8.8.8 and 8.8.4.4
If not, I'll try again 🙂
