Distinguished Guru
Message 11 of 16
Re: Infinity line speed drop after line fault corrected
I think that the max attainable has really fallen the same on both lines, but interleaving is causing a higher max attainable to be reported on the slower line.
If not, I'll try again 🙂
Message 12 of 16
With any luck the interleave will go away and we'll know for sure 🙂
Distinguished Guru
Message 13 of 16
Have you got the latest firmware on those HG612s so that G.Inp may work?
Message 14 of 16
I'm not certain, it looks like the web interface has vanished (althought the cli is still working), so it's possible an update occurred. Do you know the latest version number and I'll check?
Distinguished Guru
Message 15 of 16
No, but you may see some hints in the stats, such as mention of G.Inp or Bearer 0 and Bearer 1
Message 16 of 16
Great news! (thanks Ray)
The adaptive algorithm appears to work very quickly (the problem seems to have been caused by a nearby Sure Signal box 0.8m away). A short period of time (two days) later, looking at the stats this evening:
The interleaving has dropped way back and ping speeds are at 15 ms;
The attainable speed has increased slightly from 86960 to 87416 kbps; and
The actual speed went from 70291 to 79999.
I wonder if this means a metal housed ADSL modem is a good precaution for those (most) of us with nearby SureSignal boxes?
