colinb4987
Message 1 of 5
Infinity "dropping out"
So I've had Infinity 2 since October, and it's been working fine for everything I need - internet browsing, HD streaming, BT sport viewing (via YouView box), and Spotify through my stereo (via Spotify Connect). That is, until about the middle of this week.
BT Sport now drops out frequently, resukting in an IPC6023 error. Streaming to my desktop (over gigabit ethernet) drops out frequently. Spotfiy Connect drops out frequently. Speedtests however, don't show any issues - other than the Wholesale test occasionally delivering an "Error 2023".
HH5 has been rebooted, and 30-30-30 reset to no avail.
Can anyone shed any light on this for me? My external IP is 86.191.214.237 should that help diagnoses
4 REPLIES 4
ray_dorset
Distinguished Guru
Message 2 of 5
Re: Infinity "dropping out"
Is the Youview box connected over Ethernet, or over wifi, or Homeplugs?
If not, I'll try again 🙂
colinb4987
Message 3 of 5
Ethernet, via a switch. Removing the switch from the path makes no difference.
ray_dorset
Distinguished Guru
Message 4 of 5
Sorry, what's a 30-30-30 reset?
colinb4987
Message 5 of 5
Appears resolved - after switching the port on the HH, all back to normal.
