nickhok
Message 1 of 10
Infinity speed drop
Recently renewed with BT Infinity and have noticed that my speeds have dropped from 34mbps down and 7mbps up to 26mbps down and 5.7 up. Nothing has changed at my end so am assuming that something has changed at BT's end. Ran the btspeed test and results are below, is the IP profile correct?
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download Speed
 26.07 Mbps
0 Mbps26.52 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 26.07 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-26.52 Mbps .
 Additional Information:
 IP Profile for your line is - 26.52 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 4.85 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 4.85Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
The test result has indicated that you should contact your ISP for further assistance.
Please visit the FAQ if you are unable to understand the test results.
9 REPLIES 9
imjolly
Message 2 of 10
Re: Infinity speed drop
if using a hh5 can you go to troublkeshooting then helpdesk and post 1-12
can you enter your phone number and post results https://www.btwholesale.com/includes/adsl/main.html
nickhok
Message 3 of 10
Results are below, not using hub5 due to dropouts.
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
  HighLowHighLow
FTTC Range A (Clean)38.8307.65.7--Available
FTTC Range B (Impacted)33.1187.63.7--Available
WBC ADSL 2+Up to 14--10 to 17.5Available
WBC ADSL 2+ Annex MUp to 14Up to 110 to 17.5Available
ADSL MaxUp to 6.5--5.5 to 8Available
WBC Fixed Rate2----Available
Other Offerings
FTTP on Demand33030--Available
Fibre Multicast------Available
Copper Multicast------Available
imjolly
Message 4 of 10
are you using a modem or can you post any stats from your router
from the dslchecker results your estimated max  is 38.8mb and as that is below the infinity 1 max of 40mb then I would suggest you downgrade from infinity2 to 1 and save some money   i would phone options team on 0800800030  they are uk based
nickhok
Message 5 of 10
Using tp-link n600
Line Status:Connected
DSL Modulation Type:VDSL2
Annex Type:Annex A/B/L/M
  Upstream DownstreamCurrent Rate (Kbps)Max Rate (Kbps)SNR Margin (dB)Line Attenuation (dB)Errors(Pkts)
626527400
813740986
6.98.7
38.223.9
00
imjolly
Message 6 of 10
your max rate of 40mb is at the infinity 1 limit so certainly I would downgrade to infinity 1 and save some money
your noise margin is high at 8.7 are you having problems with router dropping connection?
try quiet line test  dial 17070 option 2  should be quiet and best with corded phone
nickhok
Message 7 of 10
Yes I had trouble with Hub 5 dropping connection, tried the noise test , line was quiet. Still not sure why speed has dropped to 25-27 mbps from a constant 34 mbps before I renewed contract, its like i've been downgraded 😞   Will have to keep Infinity 2 as I need the unlimited option. Starting to think I made a mistake renewing with BT.
imjolly
Message 8 of 10
I would phone the options team and see what they offer - at least try as freephone number and they are uk based and usually very helpful
pippincp
Sage
Message 9 of 10
Infinity 1 is unlimited.
nickhok
Message 10 of 10
Really? then i need to look into it , thank you.
