Crob
Message 1 of 21
Infinity speed drop
I have had a reliable connection at 75Mbs for over 2.5 years yet is suddenly dropped to virtually nothing then went to 50Mbs. I reported the fault and went through every check possible and was then told an engineer would call. I then got a call to say the call had been cancelled because the fault at the exchange had been fixed. The speed is stable but at around 50mMbs and the line profile is set to 53Mbs although the line is said to be capable of much more. Screen shot attached. How can the line profile be reset?01433631685-edited.jpg
20 REPLIES 20
pippincp
Sage
Message 2 of 21
Re: Infinity speed drop
Can you post the connection stats  from the hub.
See HERE.
DavidM
Moderator
Moderator
Message 3 of 21
Hi @Crob and welcome.
I'm sorry you're connection speed has dropped. If you can post the details as requested by @pippincp I'm sure we'll be able to help.
Cheers
David
Crob
Message 4 of 21
I do not want to make my landline number public but will supply in a private message
Webby
Message 5 of 21
It’s the connection stats from the hub we need, not the DSL checker results.
pippincp
Sage
Message 6 of 21
If you click on the link in my previous post it will tell you how to get the stats.
Zombie
Expert
Message 7 of 21
@pippincp the link is directing to the dsl checker.
Zombie
Expert
Message 8 of 21
This is a copy and paste job from another post. I think this is what @pippincp wants to see.
Please post your Home Hub router stats
Learn how from here Broadband Top Tips
Full router stats are key to any speed & connection issues.
Crob
Message 9 of 21
The link takes me to the DSL speed checker at BT Wholesale. How do I get what you want?
Crob
Message 10 of 21
Is this what you need?
