sproey
Message 1 of 11
Infinity speed fluctuating dramatically?
Hi,
Can somebody please help?
My broadband speed is all over the place, i am supposed to be on Infinity 2 and just lately(last couple of days), it has been anything but.
The speeds range from 16 mb to 69mb but do not stay constant, i used to have a steady download speed of 79mb when this was installed in October and to be fair, the connection has been flawless and stayed the same up untill the last couple of weeks.
I would appreciate a prompt response to this please, as this has been the "light at the end of the tunne" with regard to all the issues i have had after transfering from Sky in October. This has been the ONLY thing that has worked as it should.
Regards
Robert Sproson
10 REPLIES 10
legitimise_sailing
Distinguished Expert
Message 2 of 11
Re: Infinity speed fluctuating dramatically?
Are you connected to the Homehub over wifi or using ethernet?
To say thanks for a helpful answer, please click the white star
sproey
Message 3 of 11
Hi,
Thanks for the reply, i am connected via ethernet cable. I have reset the hub, powered off and on and run the BTW Performance tests
legitimise_sailing
Message 4 of 11
Do you have another PC to confirm the problem is not your PC.
sproey
Message 5 of 11
Yes, and tried and still the same unfortunately
legitimise_sailing
Message 6 of 11
Have you tried different speedtesters to rule out the BT performance test?
http://www.thinkbroadband.com/speedtest.html
http://www.speedtest.net
sproey
Message 7 of 11
Hi ,
Yes before - just retried BT and speed is now back up for the moment - it is fluctuating quite alarmingly. Suppose i will just have to suck and see for a while, i have sent a complaint in via the contact us on the BT web page- don't know if that will prompt an investigation or if this is just temporary? With having such a fantastic speed normally, i don't tend to notice the variations, until it is very aparent(very slow page opening) and it could have been fluctuating from install.
legitimise_sailing
Message 8 of 11
What Homehub are you using?
sproey
Message 9 of 11
Hi,
Home hub 4
legitimise_sailing
Message 10 of 11
Oh, that's lucky. You can try connecting the modem directly to the PC to rule out the Homehub as the problem, as described here https://community.bt.com/t5/BT-Infinity-Speed-Connection/No-Connection-only-orange-light/m-p/1164618...
