connecting to the test socket eliminates any problems that could be caused by extension wiring in your home
... assuming that the extensions are disconnected when you remove the face plate and that they have not been star wired. To be sure check the extensions for a dial tone when you connect to the master socket. There should not be any tone.
ah yes! "internal wiring" would have been better. Sorry
BT Hub 6A
+084319+NQ62052623
SG4B1000223E
24-Nov-2016
1.0
1.32.0
0 Days, 22 Hours 0 Minutes 10 Seconds
3.35 kbps / 25.56 kbps
3352 / 26795
6 / 6.5
25.5
0/38
G_993_2_ANNEX_B
Fast Path
3780 MB Uploaded / 2278 MB Downloaded
bthomehub@btbroadband.com
Active
BTHub6-G7M2
Smart (Channel 1)
BTHub6-G7M2
Smart (Channel 36)
WPA2 (Recommended)
Off
Mode 1
On
90:4D:4A:10:52:41
7.33.1
Can you elaborate ? do you think a Mod will pick this up and arrange ???
No, you need to report a fault on 0800 111 4567
Thanks but what exactly from the stats indicates to you that there is a fault, would be useful to know for the future.
