gazamataz
Message 1 of 19
Infinity speed has dropped by 12Mb - now Ultra HD sport no longer works
May – 2016 cabinet upgraded to infinity initial speed on connection 44Kbps which then settled to 36Kbps, Ultra HD4k sport channel ordered and working fine.
Mid November - speed drops to 24Kbps not enough bandwidth for Ultra 4k so channel no longer works.
Contacted BT who say they are providing the guaranteed speed therefore nothing more than they can do.
BT.com states  you could get 30Mb - 40Mb,  You currently get 30Mb - 40Mb (i don't), 27Mb Minimum speed guarantee.
recent speed check (PC directly wired from master socket into HH6) shows
Download speedachieved during the test was - 22.89 Mbps
For your connection, the acceptable range of speedsis 16.62 Mbps-23.74 Mbps .
Additional Information:
IP Profile for your line is - 23.74 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
3.75 Mbps
0 Mbps 20 Mbps
Max Achievable Speed
Upload speed achieved during the test was - 3.75Mbps
Upstream Rate IP profile on your line is - 20 Mbps
I have also had recent issues with wifi connections to the Hub.
Can anyone here offer any suggestions or can a Mod help check the line / IP profile etc
18 REPLIES 18
Webby
Message 2 of 19
Re: Infinity speed has dropped by 12Mb - now Ultra HD sport no longer works
Are you connected to the master socket or an extension socket?
gazamataz
Message 3 of 19
 master socket into HH6 - ethernet into PC
john46
Message 4 of 19
If you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
The stats for the Home Hub 6 can be found on the Information page from http://192.168.1.254 then Advanced Settings -> Technical Log.
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting
pippincp
Sage
Message 5 of 19
Have you tried a quiet line test? 17070 option 2. Any noise report as a line fault don't mention broadband.
Boudges
Message 6 of 19
Please may you run this check? BT BROADBAND AVAILABILITY CHECKER. Then post a sreenshot of the results. Remember to delete the telephone number from the results as this is a public forum that can be viewed by anyone.
If you liked a post, please click on the 'Ratings star' on the left hand side of the post.
gazamataz
Message 7 of 19
Webby
Message 8 of 19
Can you remove the faceplate and connect to the test socket.
Once you've done that can you post up the connection stats from the home hub management page?
gazamataz
Message 9 of 19
I will, it is a brand new socket recently fitted by BT so will it make a difference connecting to the test socket ?
Webby
Message 10 of 19
