Boudges
Message 11 of 19
Re: Infinity speed has dropped by 12Mb - now Ultra HD sport no longer works
connecting to the test socket eliminates any problems that could be caused by extension wiring in your home
If you liked a post, please click on the 'Ratings star' on the left hand side of the post.
gg30340
Message 12 of 19
... assuming that the extensions are disconnected when you remove the face plate and that they have not been star wired. To be sure check the extensions for a dial tone when you connect to the master socket. There should not be any tone.
Boudges
Message 13 of 19
ah yes! "internal wiring" would have been better. Sorry Smiley Sad
gazamataz
Message 14 of 19
Product name:
BT Hub 6A
Serial number:
+084319+NQ62052623
Firmware version:
SG4B1000223E
Firmware updated:
24-Nov-2016
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
0 Days, 22 Hours 0 Minutes 10 Seconds
Data rate:
3.35 kbps / 25.56 kbps
Maximum data rate:
3352 / 26795
Noise margin:
6 / 6.5
Line attenuation:
25.5
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
3780 MB Uploaded / 2278 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-G7M2
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-G7M2
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
90:4D:4A:10:52:41
Software variant:
Boot loader:
7.33.1
Webby
Message 15 of 19
You need an engineer visit.
gazamataz
Message 16 of 19
Can you elaborate  ?  do you think a Mod will pick this up and arrange  ???
licquorice
Message 17 of 19
No, you need to report a fault on 0800 111 4567
gazamataz
Message 18 of 19
Thanks but what exactly from the stats indicates to you that there is a fault,  would be useful to know for the future.
Webby
Message 19 of 19
The max rate is below the mininum expected speed for yor line
