Message 1 of 14
Infinity speed issues - several visits no resolutions
Hi I was wondering if anyone could help.
I have had a number of visits from engineers. We are fairly remote and top speed expected to be 17.5.
Last visit we were told it might be internal. In the event they changed the phone line outside in the village. I still got charged but didn't bother arguing as it fixed the problem.
Up from 8 to 17.5. Told the line would stabilise over the coming week.
That it did....to a steady 11.5.
Same pattern after every visit. Improved speed then looks like it's throttled back. Always suggested it must be internal but given it ran fine for 3 days this doesn't seem to make sense to my untechnical mind. Exact same performance with either homehub or the Asus router we use.
I'm sure its a capacity issue in some form.
13 REPLIES 13
Message 2 of 14
Re: Infinity speed issues - several visits no resolutions
Welcome to this user forum.
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Then, if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post lines 1-12
Or post the information from the smart hub, using this link.
http://192.168.1.254/0000012803/gui/#/technicalLog/information
Which one of these matches your master phone socket?
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Could you please post the results from the BT Wholesale speed checker, including the further diagnostics.
Message 3 of 14
1. Product name:BT Home Hub
2. Serial number:+068543+NQ51600620
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 06/09/15
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 00:37:29
6. Data rate:1975 / 14920
7. Maximum data rate:1967 / 16046
8. Noise margin:5.3 / 6.2
9. Line attenuation:39.9 / 30.3
10. Signal attenuation:39.2 / 25.7
11. Data sent/received:99.3 MB / 124.6 MB
12. Broadband username:bthomehub@btbroadband.com
Message 4 of 14
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  HighLowHighLow
ADSL Products
Availability Date
Left in Jumper
Other Offerings
Availability Date
VDSL Range A (Clean)23.817.43.72--Available----Yes--
VDSL Range B (Impacted)21.710.730.8--Available----Yes--
WBC ADSL 2+Up to 1--1 to 3.5Available--------
ADSL MaxUp to 1--0.75 to 2.5Available--------
WBC Fixed Rate0.5----Available--------
VDSL Multicast------Available--------
ADSL Multicast------Available--------
Message 5 of 14
There is low level crackling on the quiet line test, although we only have a wireless handset so cant be sure that it is not poor quality on that.
I have also switched back in the homehub in replacement of the asus router and that has boosted the speed to 13.5
Message 6 of 14
The maximum data rate falls into impacted range B.
This can point to a wiring error within you home wiring, which is why I asked you about which master socket you have, as that, and any extensions, can affect the connection speed.
If you have the first one.
Try connecting things up as shown below, and see if the connection speed increases.
This should also disconnect any extensions, and there should be no dial tone on any of them.
Message 7 of 14
Thanks for all the help
I have number 4 in the list.
The master socket was upstairs, but part of the reason for the charge I am told is that they have relocated it downstairs.
When they did the work last it was running at full speed for a week before it then slowed down again.
Message 8 of 14
If its one of these
Then the external line coming in, must terminate on that socket. The home hub need to be plugged into the top, and the phone into the botton.
Any extensions must be connected to the back of the bottom removable section, so that they are totally disconnected when the bottom section is removed.
This diagram shows how things must be wired, to avoid impacting on your connection speed.
Any other arrangement will result in a loss of speed.
There is a test socket behind the master socket which you can use if you have a spare microfilter.
Provided that the main incoming line terminates on this master socket, and there are no other extensions teed in, then testing at this point will prove whether it the external network causing the impacted figures.
Message 9 of 14
Thanks Keith
The speed test is the same if I use the test socket with a filter.
Our master socket was originally upstairs, but openreach worked on it to terminate at this socket I believe. That was the justification for the charge on the last visit.
If the answer is that it is still internal wiring I sort of understand, but it seems a little galling to have paid for internal works, that have had no effect.
Message 10 of 14
Do you have any extensions?
