bilsy
Message 1 of 8
Infinity speed issues.
Hello
I have until recently had a very stable infinity connection. However, recently in the evening, the speed has been dropping to no better than the old adsl connection I has prior to Infinity.
I have an IP profile of 29mb and usually get download speeds between 25-28mb, upload 5mb.
My current download speed is 5.5mb
Does anyone have any ideas about what is going on?
I have an open fault with BT but they are yet to come back to me.
Thanks.
7 REPLIES 7
Sage
Message 2 of 8
Re: Infinity speed issues.
If you have an open fauilt...
bilsy
Message 3 of 8
The fault has been open for a few days now and they haven't come up with anything as yet. Just posting to see if anyone has simlar issues - fine during the day, slowing down in the evening.
Distinguished Expert
Message 4 of 8
What Homehub do you have?
To say thanks for a helpful answer, please click the white star
bilsy
Message 5 of 8
HH3.
Message 6 of 8
In that case, try a direct connection between the PC and the modem using a broadband-PPPOE link to see if the problem is due to the Homehub.
Neal1971
Message 7 of 8
The speed issues here are being seen by quite a few people, including myself, and I've tested my line using the HomeHub 4 and another router...both with the same results...the problem lay either with the IP Profiler, Service/Data Centres or the exchanges...and quite possibly problems caused by the adverse weather.
Message 8 of 8
The test I suggested doesn't use a router - the idea is to rule out the router completely, not guess as to possible causes.
