Message 1 of 10
Infinity speed
Good evening, just a quick question.
A about a Month ago I had infinity installed and was getting a down load speed of around 35 Mbps, however, now I'm only getting 3 Mbps, Can anyone explain this? I have tried all the basic stuff like disconnecting the router etc. It just seems to be getting worse! Any advice would be appreciated.
Many Thanks.
9 REPLIES 9
Recognised Expert
Message 2 of 10
Re: Infinity speed
Do you keep turning off the home hub and modem?
Message 3 of 10
Re: Infinity speed
No, it seems to be getting slower and slower!
Recognised Expert
Message 4 of 10
Re: Infinity speed
Please could you do a speedtest : http://www.speedtester.bt.com/
Then post the results including your download and upload profiles.
Message 5 of 10
Re: Infinity speed
Ok thanks, ill check that out tomorrow and post the results.
Thanks for your help!
Guru
Message 6 of 10
Re: Infinity speed
Also, please let us know if you are using a wired connection to the HomeHub, or a wireless one.
Message 7 of 10
Re: Infinity speed
Ok the test results were as follows
Down load speed, 24.01 mbps
Up load speed 8.1 mbps
Ping 29.5 ms
I was connected to web using cat 5 cable, huge difference from last night, I was seeing speeds as low as 3 mbps down load speed!
And ideas?
Sage
Message 8 of 10
Re: Infinity speed
We need you to do the ADSL/FTTC speedtest given in the link above (and below) to get your IP profiles.
Are you now saying last night was a wireless connection when you only got 3Mbps?
Message 9 of 10
Re: Infinity speed
Hi there, I couldn't conduct that test, basically I kept getting an error message! Not sure why? It would run for a while and then error message!
i'll try again at the weekend, should it just run when you press start?
many thanks
Guru
Message 10 of 10
Re: Infinity speed
Hi,
Try this one http://www.speedtest.btwholesale.com/
You will need to go on further diagnostics, if that doesn't work try the one below.
http://windows.mouselike.org/be/?DoAction=BrasChecker
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
