vjk
Message 1 of 7
Infinity speeds 15 Mbps lower than expected
Hi all,
I had Infinity 2 installed on the 26th March 2013.
BT.com/Infinity show I can get "59Mb Download speed" and "20Mb Upload Speed", while ADSL shows "6Mb estimate download speed, 4Mb-8Mb Download speed range".
In reality I was reliably getting 12 Mbps for some reason... (on ADSL).
Once I got Infinity 2 installed, I seem to be only getting about 42Mbps reliably. Very occasionally I can get ~48Mbps on various speed tests.
Looking at the modem stats, I see a very high amount of CRC errors.
System up time
3 days 23 hours 12 minutes 5 seconds
CRC errors
50329
I suspect these errors are causing my connection to not be as high as it should be.
I had Infinity 2 in a previous property, and download speed was 'promised' at 66.8Mbps, but in reality I was getting full 80Mbps.
How do I get my full 59Mbps, because currently it's almost not worth paying the extra for Infinity 2 when I am not getting much better than Infinity 1 speeds?
Tags (2)
6 REPLIES 6
Big-Tabs-AKA-Kyle-93
Message 2 of 7
Re: Infinity speeds 15 Mbps lower than expected
Same problem as me they will most likely send engineer out if noting can be done bt will hide behind ITS A UP TO SERVICE
ryant704
Guru
Message 3 of 7
Yours errors are not high and are nothing to worry about it.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
TimCurtis
Recognised Expert
Message 4 of 7
System up time
CRC errors
50329
Looks like you're using an unlocked Huawei and the stats are from the GUI.
There maybe an error with the display as if you telnet into it those CRC errors are shown as FEC errors & vice versa. Gives a totally different picture.
vjk
Message 5 of 7
Thanks TimCurtis,
Will verify this once I get home.
As for the "Up To" service, it's "up to 76Mbps" but the number checkers all state pretty you will get 59Mbps - it doesn't state anywhere that those are an estimate or you will get within a range, as it does with ADSL.
I just want to make sure I am getting what I am paying for, or else I may as well try and 'downgrade' to the 40Mbps service.
Deathtrap3000
Recognised Expert
Message 6 of 7
This is what I get if I put my number into the wholesale speed checker site.
Telephone Number 020xxxxxxxx on Exchange CHINGFORD is served by Cabinet xx
Available ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
Featured Products
WBC FTTCUp to 77.7Up to 20--Available
WBC ADSL 2+Up to 7.5--6.5 to 8.5Available
WBC ADSL 2+ Annex MUp to 7.5Up to 16.5 to 8.5Available
ADSL MaxUp to 6--5 to 8Available
WBC Fixed Rate2----Available
Other Offerings
Fibre Multicast------Available
Quite a lot of "up to's" mentioned there.
Although no "up to" mentioned when you put your number in on the bt site to see what speed you will get
on the same page the t&c's mention it is an estimated speed.
@BT wrote:
BT always offers you the best speed possible on your line. The speed prediction we have given here is an estimate, however download speeds can vary and the actual download speed will fall within a range. The BT broadband range is an indication of the speed that other similar lines across the UK have achieved for their broadband service; this is generally within 1-2 Mb higher or lower than your single estimated speed quoted for BT broadband.
The actual speed is dependent on several factors such as the product option you choose, the processing power of your computer, how many people are using your broadband connection at the same time, whether you use a wireless or cable connection, the speed of the websites that you visit and the performance of our network. Speeds can be lower at peak times – peak times are evenings and weekends.
And its also mentioned as "up to" on the product details pages.
Bald_Eagle1
Message 7 of 7
Once you have started a telnet session (via 'tenet 192.168.1.1'), the username is 'admin' & password is also 'admin' (without the quotes).
at the next prompt type 'sh' & then at the next prompt type 'xdslcmd info --stats' (all without the quotes).
You should then get something like this:-
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason:	0
Max:	Upstream rate = 5561 Kbps, Downstream rate = 30648 Kbps
Path:	0, Upstream rate = 5701 Kbps, Downstream rate = 26007 Kbps
Link Power State:	L0
Mode:			VDSL2 Annex B
VDSL2 Profile:		Profile 17a
TPS-TC:			PTM Mode
Trellis:		U:ON /D:ON
Line Status:		No Defect
Training Status:	Showtime
		Down		Up
SNR (dB):	 6.3		 5.8
Attn(dB):	 0.0		 0.0
Pwr(dBm):	 12.6		 6.3
			VDSL2 framing
			Path 0
B:		63		175
M:		1		1
T:		64		38
R:		16		14
S:		0.0783		0.9794
L:		8175		1552
D:		413		1
I:		80		95
N:		80		190
			Counters
			Path 0
OHF:		112056344		355090
OHFErr:		21240		130
RS:		39981357		4159747
RSCorr:		20011751		270
RSUnCorr:	783458		0
			Path 0
HEC:		200907		0
OCD:		0		0
LCD:		0		0
Total Cells:	3936410335		0
Data Cells:	32981218		0
Drop Cells:	0
Bit Errors:	0		0
ES:		1456		130
SES:		2		0
UAS:		102		102
AS:		422734
			Path 0
INP:		3.00		0.00
PER:		3.75		9.30
delay:		8.00		0.00
OR:		51.09		27.51
Bitswap:	116632		6463
Total time = 1 days 21 hours 27 min 48 sec
FEC:		20011751		270
CRC:		21240		130
ES:		1456		130
SES:		2		0
UAS:		102		102
LOS:		0		0
LOF:		0		0
Latest 15 minutes time = 12 min 48 sec
FEC:		2817		0
CRC:		3		0
ES:		1		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
Previous 15 minutes time = 15 min 0 sec
FEC:		61799		1
CRC:		234		0
ES:		11		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
Latest 1 day time = 21 hours 27 min 48 sec
FEC:		1317278		53
CRC:		1183		23
ES:		138		23
SES:		2		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
Previous 1 day time = 24 hours 0 sec
FEC:		3693914		51
CRC:		3858		34
ES:		255		35
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
Since Link time = 4 days 21 hours 25 min 33 sec
FEC:		20011751		270
CRC:		21240		130
ES:		1456		130
SES:		2		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
