Weavus
Message 1 of 4
Infinity street cabinet 5 meters from house but cannot get Infinity!?!
The infinity cabinet is 5 meters away from my property (and is active, and has been for over a year) but the infinity checker still says I cannot get infinity.
Is it possible to check if this is a mistake in the database or there is any way to change my line so I can get infinity? My postcode is E3 2QN.
They have even stuck a big "Infinity Is Here!" sticker on the cabinet now to rub it it...
3 REPLIES 3
Webby
Message 2 of 4
Re: Infinity street cabinet 5 meters from house but cannot get Infinity!?!
Contact the moderators
Weavus
Message 3 of 4
Thanks... but how do I do that.. do I need to private message someone in particular? Or is there some other way of doing it?
john46
Message 4 of 4
I suggest you contact the forum mods they should be able to get your problem sorted for you this is a link to them
http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone directly to you within 3 working days
They are a UK based BT specialist team who have a good record at getting problems solved
