ouzlewell
Message 1 of 5
Infinity v Total Broadband Option 3
Hi,
I currently have BT Infinity (17Mb/1Mb) installed but when I tried to upgrade to Infinity 2, I get a message indicating that an upgrade isn't possible.
If I perform the 'Can I get Infinity' check, I am told that the best that I can get is Faster Total Broadband up to 12Mb.
Could somebody please tell me what the difference is between faster total broadband and Infinity, because when the BT Engineer was installing it, he said it was Infinity and he's installed Infinity kit.
4 REPLIES 4
Guru
Message 2 of 5
Re: Infinity v Total Broadband Option 3
Faster Total Broadband option 3 is for people who would receive less than 15MB from Infinity, considering that your on 17/1MB im guessing this is a good thing. Infinity 2, based on your current download speeds i wouldn't bother, since it using higher frequencies and over a long line from the cabinet like yours, wouldn't be a good idea.
I reckon you should stay put, even people who have had higher estimates have had issues.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
ouzlewell
Message 3 of 5
Thanks for the prompt reply.
That's answered my question.
evp
Newbie
Message 4 of 5
On Tuesday 17 April engineer installed BT Infinity for 12PM connection lost at 3 PM have been in touch with helpdesk in India every day & still no connection .
I need to know when my connection will be up & running & why the delay. HELP !!!!!
14 Days no internet & still counting.
How long does i
Guru
Message 5 of 5
Hi evp, i would recommend you get on to the mods: http://community.bt.com/t5/user/viewprofilepage/user-id/26825
It does take up to 3 days to get a response from them, but they are very good at getting issues resolved.
