kpjunk
Aspiring Member
Message 1 of 4
Infinity via Poles
Is there anyone who knows about fibre over telegraph poles ?
The BT Checker says that my number will be available from June 30th
What do I need to look for to see if this is likely?
Keith
3 REPLIES 3
Distinguished Guru
Message 2 of 4
Re: Infinity via Poles
Keith
Does the BT checker specifically say FTTC or FTTP
toekneem
(EASBF)
kpjunk
Aspiring Member
Message 3 of 4
The BT Checker states FTTC
Your cabinet is planned to have WBC FTTC by 30th June 2011. Our test also indicates that your line currently supports a fibre technology with an estimated WBC FTTC Broadband where consumers have received downstream line speed of 27.9Mbps and upstream line speed of 6Mbps.
Distinguished Guru
Message 4 of 4
That wwill be Fibre To The Cabinet, not FTTP.
You should see some New green Cabinets, see here: http://postimage.org/image/2iszf4mec/ within a few yards of the old cabinets.
If they are in placemaybe you are on course timescale wise.
If they are not yet in place, you have quite a little while to wait
toekneem
(EASBF)
