quospice
Message 1 of 5
Infinity
My father in law has ordered infinity and bt vision. He has been told an engineer visit is not required. I thought an SSFP had to be fitted which means an engineer has to visit. HELP!
4 REPLIES 4
imjolly
Message 2 of 5
Re: Infinity
you can connect the router to a filter and then to master socket - just like adsl - and probably how he connected at present
is it infinity 1 as that is now self install
quospice
Message 3 of 5
Re: Infinity
He has never had internet before. He ordered Infinity extra and calls.
imjolly
Message 4 of 5
Re: Infinity
I think that is infinity 1 up to 38mb
You will get the hh5 and a couple of filters. You then connect one of the filters into the master socket and then conenct the router to the filter and you are finished. Any other sockets in use will need a filter including SKY
imjolly
Message 5 of 5
Re: Infinity
This may help. http://bt.custhelp.com/app/answers/detail/a_id/47225/~/help-with-setting-up-bt-infinity-yourself
