Foobs
Message 1 of 3
Infinty 2 speed issues
Over the last mont or so I have had periods of speend issues on my Infinity 2 line (coming up for 12th month).  It will be ok for a few days, although it's still slow, but then it will disconnect constantly with 10-15 minutes of connection.
When it is working it usually runs around the 5Mbps range.  After reading a number of posts on here I have used the Wholesale speed test and had consistent results of 9-10 Mbps downstrem and 9-12 Mbps Upstream.  I then ran the wholesale performance test and got these results:
1. Best Effort Test: -provides background information
 Download speedachieved during the test was - 10.32 Mbps
 For your connection, the acceptable range of speedsis 60 Mbps-76.8 Mbps .
 Additional Information:
 IP Profile for your line is - 76.8 Mbps
Upload speed achieved during the test was - 12.71Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
I've had no disconnections to my knowledge, but had a powercut a week or so ago.
Wholesale Availability checker:
Featured
Products
WBC FTTP
Downstream
Line rate Mbps
Up to 330
Upsream
Line rate Mbps
Up to 30
Availability
date
Available
Any ideas?
Thanks,
Foobs
2 REPLIES 2
legitimise_sailing
Distinguished Expert
Message 2 of 3
Re: Infinty 2 speed issues
You seem to be saying you're on FTTP not FTTC. Is that correct?
To say thanks for a helpful answer, please click the white star
Foobs
Message 3 of 3
Yes that's correct.
