miked1963
Message 31 of 36
Re: Infnity speed/connection issues
Anyone ?????
Mike
pippincp
Sage
Message 32 of 36
Turn off smart wireless and select the best channel suited to you.
miked1963
Message 33 of 36
Hi yes I have to do that but does it make a difference with ethernet ?
Also can anyone tell me if my stats are good noise etc ?  as the speeds dropped from 49 again trying to find out why this
keeps happening.
Mike
miked1963
Message 34 of 36
Smart wireless is now turned off,
can anyone tell me if my stats look ok ?
Mike. Smiley Happy
pippincp
Sage
Message 35 of 36
They look OK
miked1963
Message 36 of 36
Thanks.
I guess I'm going to have to settle for these slower speeds, looks like my line can no longer sustain the speed after tbe DLM.
Thanks again.
Mike
