miked1963
Message 1 of 36
Infnity speed/connection issues
Hi all
Had infinity installed back in November, after a few issue s everything seemed resolved I/P and max speed used to vary between 45/47. speeds used to vary wirelesly between 42/49. now since the end of Feb its all over the place. speeds go as low as 10 and go up to about 41. The I/P and max speed have also dropped to about 40/41.
Also the wireless connection some evenings can be impossable to use, (nothings changed) Have been in touch with BT,
they have run tests but have come up with nothing.
Mike
FAQ
BT Wholesale Broadband Performance Test
Broadband Speed Test Results
http://www.speedtest.net/my-result/3391061710
35 REPLIES 35
miked1963
Message 2 of 36
Re: Infnity speed/connection issues
Managed to get a half decent test this morning, but  still not as good as it was
FAQ
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download Speed
 42.33 Mbps
0 Mbps42.63 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 42.33 Mbps
 For your connection, the acceptable range of speedsis 34.11 Mbps-42.63 Mbps .
 Additional Information:
 IP Profile for your line is - 42.63 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 5.26 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 5.26Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding
and its up and down all the time.
miked1963
Message 3 of 36
Any one ?
Mike
badmonk
Message 4 of 36
might be silly asking this but is your hub set to smart wireless? because i found when its looking for best channel sometimes it can throw you onto a busy channel by mistake or just keep hopping between channels and this kinda makes the connection unstable.
i set mine to a certain channel and seems to be much better 🙂
for eg 2.4ghz to channel 11 and 5ghz to channel 48, these are just examples of course
badmonk
Message 5 of 36
also those speeds are only a couple mbps difference here and there so i wouldn't worry about it, but re it being up and down i would try not using smart wireless and see if that helps 🙂
miked1963
Message 6 of 36
No it is set to channel 1 most houses in my street seem to be on it, but no other channel seems to work very well, there was no issue until the end of Feb, it was really stable, between 42/49 wireless or Ethernet, I was talking to one of the stage two team this morning and she thinks there could be an issue with the install as there is no Cable going to the internet part of the master socket it piggybacks off an old BT phone extension splitter, so in other words both the phone and the internet cable go in to the phone part of the master socket.
Mike
Keith_Beddoe
Message 7 of 36
miked1963
Message 8 of 36
Sorry it won't let me access it says its a private website.
Mike
miked1963
Message 9 of 36
Hi again.
Its the RJ11 connector I don't have. Just the twin pair in to the back of a two way phone splitter. Don't know if this would cause the problem or not as its been working very well for quite a while.
Can't access the links you sent me. Thanks for trying though.
Mike
Keith_Beddoe
Message 10 of 36
Mike
You have to be connected to BT Broadband to use my website.
