Message 1 of 2
Info vedio
Clicked on vedio on how to connect hub6 to android nothing happens, no vedio
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Info vedio
Hi @herodummy,
If you take a look at Help for BT Hubs, you'll find instruction on how to connect to your Smart Hub.
PaddyB
