Message 1 of 4
Infrared repeaters
I am currently using the black bt vision box and my ir reader won't work. The box is connected by skart to my t.v.
Does anyone know if they do work with the bt vision box or how to make them work?
3 REPLIES 3
Distinguished Guru
Message 2 of 4
Re: Infrared repeaters
Has it ever worked? what is the model of the IR Repeater?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 4
I'm using Nikkai entertainment ir repeater. Only tried installing it tonight and having no success
Message 4 of 4
Guys i would recommend SLX Omni link ones, they work a charm
