Ray500
Message 1 of 8
Insanely slow speeds
This connection has been awful but now it's gone too far. Our upload speed of 10kb means it's impossible to online game and slows done everything else. Our download speed today is also down to 160kb.
ADSL line status
Connection information
Line state  Connected
Connection time0 days, 0:10:32
Downstream3,136 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)9.8 dB / 10.0 dB
Line attenuation (Down/Up)58.0 dB / 31.5 dB
Output power (Down/Up)18.6 dBm / 12.4 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)183 / 0
CRC Errors (Down/Up)0 / 2147480000
HEC Errors (Down/Up)nil / 0
Error Seconds (Local)0
7 REPLIES 7
chris6273
Recognised Expert
Message 2 of 8
Re: Insanely slow speeds
Hi Ray500, Welcome to the Forums 🙂
Your line stats indicate you should be recieving around 2000Kbps throughput (A 2500Kbps IP Profile).
The BT Speedtest site is having problems at the moment but when it is fixed, please can you run a speedtest at: http://speedtester.bt.com and post the results here?
___________________________________
Like this post? Give it a Star :D. If this post answers your question, please Mark it as the Accepted Solution.
Ray500
Message 3 of 8
 IP Profile for your line is - 2000 Kbps
 Download speed achieved during the test was - 1324 Kbps
 For your connection, the acceptable range of speeds is 400-2000 Kbps.
 Additional Information:
 Your DSL Connection Rate :2880 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
It didn't do a test for upload speeds. I can give you a speed test from another site.
Message 4 of 8
are you having connection problems just your connection speed is different from yesterday suggesting a reset.  your speed has dropped to 2880 but that should give you a profile of 2500 not 2000.  that may mean that was a lower connection since yesterday
Ray500
Message 5 of 8
Yes the connection cuts out almost routinely every 30 mins or so. Very annoying.
Message 6 of 8
the usual questions are
try quiet line test  dial 17070 option 2  should hear nothing and best done with a corded phone   cordless normal is a dull him
are you connected directly to the master or test socket or to another extension socket in another room?  do you have phone extension sockets in other rooms?
Ray500
Message 7 of 8
There is a definite static sound. It's not particularly loud but it's certainly not quiet, nor is there a dull hum. We have been plugged into the main test socket for over a year now and we have no extension cords. We have no phone extensions in other rooms.
Message 8 of 8
if you have noise on your connection then you need to report a phone fault to 151 and do NOT mention broadband  get rid of the noise and help improve your broadband
