Message 1 of 2
Installation engineer access requirements
I'm having BT Fibre 250 installed next month, and an engineer is due to visit. What will they require access to? Do they set-up everything from phone socket to hub to computers, or just ensure that they master socket is setup correctly?
1 REPLY 1
Message 2 of 2
Re: Installation engineer access requirements
With G.FAST you need a new master and engineer should fit the new master and connect hub to make sure internet connection is as expected. Connecting devices is up to you
