Message 1 of 12
Installation tomorrow - couple of questions !
BT are due to install tomorrow 🙂
So I have a couple of questions.
I know I will have the HomeHub 3b and a router, will both have an IP Address ?
Can I change them to suit my network ?
Can the WPA key be changed to suit my network ?
Do you set the HomeHub as the default gateway on the PC or the router ?
Does port forwarding work OK on the HomeHub3 ?
Thanks 🙂
11 REPLIES 11
Distinguished Expert
Message 2 of 12
Re: Installation tomorrow - couple of questions !
the homehub3 is a router
the white openreach box is a modem
the homehub3 will get the wan ip address and its lan ip address is the default gateway
you can change the lan ip address
you can change the wpa key
port forwarding works
the modem is locked and inaccessible to you
Message 3 of 12
Thanks..
So for all intents ignore the modem, it's the HomeHub that I can access.
Will the modem be preconfigured, or do I need to provide them any details. ?
Guru
Message 4 of 12
The modem will be preconfigured. Unless you want to get very techie, ignore it as you say.
You should already have the HomeHub through the post or courier. The installer will bring the modem. If you want to be really prepared you can connect to the HomeHub already (with no internet access) and set up wpa keys etc. Also test out best position, wireless coverage and channels, etc.  You can set up port forwarding too, but can't test it till the modem arrives.
Message 5 of 12
the modem is pre configured by OPENREACH and will be delivered when the engineer arrives to do the install
Message 6 of 12
Hopefullt last question prior to installation.
Does the HomeHub3b offer any QoS ? Can I restrict what devices are allow what bandwidth or what priority ?
Thanks 🙂
Message 7 of 12
I've thought of another question 🙂
Does rebooting the HomeHub affect the connection ?
Just thinking about changing addresses etc will probably need a reboot !
Message 8 of 12
no you cant use qos
no rebooting doesnt affect the dlm but it may implement a change that dlm has scheduled and you get a new ip address
Message 9 of 12
So am I better to configure it tonight before BT turn up ?
What's the default IP Address on the Home Hub ?
Will the openreach engineer get 'upset' if I've pre configured the hub ?
Guru
Message 10 of 12
The default gateway is 192.168.1.254
I believe
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
