Nick123
Message 1 of 3
Installation
Hi, I'm having BT Infinity installed on Monday and wanted to know if they will use the previous BT tubbing that runs under the ground to my house (where the telephone line comes in) or have to install new. Dont really want to have the garden dug up...
Cheers
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: Installation
Hi Nick, as long as you are getting Infinity as FTTC, then they use existing copper from the cabinet to your house, so no they will not dig up your garden.
They will do some work at the cabinet, and some INSIDE your house.
Now if you are extremely lucky and having FTTP, then I cannot speak about that.
toekneem
(EASBF)
Nick123
Message 3 of 3
Re: Installation
Cool Thanks
Tags (1)
