Message 1 of 2
Insufficient bandwidth
Hello again. My problem is bt infinity does not allow iplayer on iPad .. I keep getting an insufficient bandwidth message. How can't his e fixed please . I tried to ask previously but my status has mysteriously changed to " solved " when in actual fact this is far from the case. Can someone let me know in laymans terms too please because my previous responses were more confusing than my initial problem. Thanks ( hopefully ) Matt
1 REPLY 1
Message 2 of 2
Re: Insufficient bandwidth
Posted in your other thread mate, didn't look back in as it was showing as resolved 😉
I think you can "unresolve" it though if you go back into the thread.
