Message 1 of 8
Interleave depth: 2095 , 329
how can i get this fixed i have started using a bt openreach modem after haven reboot isues with the hh5 but my interleave is extream now after using the hh5 this ids the stats below from dslstats
Stats recorded 04 Jan 2015 22:06:02
DSLAM/MSAN type: BDCM:0xa451 / v0xa451
Modem/router firmware: AnnexA version - A2pv6C038m.d24j
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 5 hours 29 min 45 sec
Resyncs: 1 (since 04 Jan 2015 21:55:13)
Downstream Upstream
Line attenuation (dB): 21.2 0.0
Signal attenuation (dB): Not monitored
Connection speed (kbps): 53067 8934
SNR margin (dB): 6.3 6.1
Power (dBm): 12.2 6.7
Interleave depth: 2095 329
INP: 4.00 4.00
RSCorr/RS (%): 0.0026 0.2683
RSUnCorr/RS (%): 0.0000 0.0000
ES/hour: 0 0
7 REPLIES 7
Sage
Message 2 of 8
Re: Interleave depth: 2095 , 329
As you have been told in your other thread there must be an underlying issue which would need an engineer out to look at.
Expert
Message 3 of 8
Might take a few weeks for the dlm to rest the counters.
BTRetail sister isp {plusnet} has some good info on how the dlm works.
http://community.plus.net/library/browsing/fttc-dlm-what-it-is-how-it-works/
The only quicker way is to ask for  an openreach boost visit for a dlm reset- which could cost £150 is no fault is found 😞
Message 4 of 8
thanks for your info but i am no taking the chance of getting charged £150 think i will hold off but are these interleave stats not a bit high and would the hh5 had caused this problem
Expert
Message 5 of 8
Mine was the same after using the HH5.
Line got back to "fast" mode in around a month with the unlocked modem. 🙂
Message 6 of 8
thanks barry57 i will leave it a month and check it again hope my unlocked modem fixes it also
Expert
Message 7 of 8
Should be coming upto the key time frame for the dlm to assess things...
Fingers cross its removes all the speed restrictions 🙂
Message 8 of 8
important question is - has you line been stable all the time or has it been resetting?  if stable then hopefully not much longer
