athlonoc
Message 1 of 2
Interleaved / Fastpath
Hi,
It's been almost 2 months since I had my DLM reset on my BT Infinity fibre connection. I have gone from 35Mb slowly down to 27399 and here it has been ever since. I was believed to understand that when it returns to fastpath it will get back up to speed.
Is this correct?
Can a mod change from Interleaved to Fastpath? and if so how?
Here are my line stats and DSL settings and wanted to know if all seems set correct or should any of the settings be altered?
I do get the odd 'internet access' loss and it drops for about 30 seconds then comes back online. Happens a couple a times a week.
Line Stats
 DownstreamUpstream
TCM(Trellis Coded Modulation)OnOn
SNR9.9 dB6.0 dB
Line Attenuation17.7 dB1.6 dB
Path ModeInterleavedFastPath
Interleave Depth26711
Data Rate27399 kbps7270 kbps
MAX Rate52908 kbps7271 kbps
POWER1.3 dbm1.9 dbm
INP1.3 symbols2.3 symbols
CRC4684466
VDSL Band Status
 U0D1U1D2U2D3U3D4U4
Line Attenuation (dB)1.617.738.450.951.981.30-0
Signal Attenuation (dB)1.834.338.452.351.6-0-0
SNR Margin (dB)6.29.669.70-0-0
Common Settings
DSL modulation
 Auto Sync Up
ANNEX Mode A/I/J/L/M
Dynamic Line Adjustment (DLA) Enabled
SRA (Seamless Rate Adaptation)
 Enabled
G.INP (G.998.4)
 Enabled
ADSL Settings
Stability Adjustment
-4 dB
Rx AGC GAIN Adjustment
 Stable
ESNP - Enhanced Sudden Noise Protection
 Default
Bitswap
 Enabled
VDSL Settings
VDSL Profile
 17a Profile
Disabled
 SNR 9.8dB
Tx Power Control
 Disabled
 Default
UPBO - Upstream Power Back Off
 Auto
Stable
Bitswap
 Enabled
G.vector (G.993.5) Disabled
1 REPLY 1
RogerB
Guru
Message 2 of 2
Re: Interleaved / Fastpath
In a word no .... only a BT Openreach broadband engineer can reset your Infinity connection and only after a line repair, that is BTo policy. There is significant error correction on the downstream path which is slowing it down a little, allbeit clearly it needs it. INP and fairly deep interleave are enabled and associated increase in margin for SNR. If it's a passive thing and temporary it may go up on its own, after time .... if not, it'll just stabilise to where it runs consistently. That's what it's designed to do. If it's within BT thresholds for performance .... it's what you get, if it falls out of them, it becomes a line repair issue.
