chrissy_t
Message 1 of 6
Interleaving Removal Enquiry
Hello,
Would like to enquire about having interleaving removed from my line in order to benefit from the lower latency.
ADSL info:
Line state
Connected
Connection time
8 days, 13:49:14
Downstream
8,128 Kbps
Upstream
448 Kbps
ADSL settings
VPI/VCI
0/38
PPPoA
Modulation
ITU-T G.992.1
Latency type
Interleaved
Noise margin (Down/Up)
12.0 dB / 23.0 dB
Line attenuation (Down/Up)
16.0 dB / 9.0 dB
Output power (Down/Up)
19.8 dBm / 12.1 dBm
Loss of Framing (Local)
0
Loss of Signal (Local)
0
Loss of Power (Local)
0
FEC Errors (Down/Up)
13202 / 0
CRC Errors (Down/Up)
64 / N/A
HEC Errors (Down/Up)
N/A / 0
Error Seconds (Local)
51
I'm not knowledgable enough to know whether or not that's a high noise margin, though I live only 0.4 miles away from the exchange, so I would hope that interleaving off would be managable on my line / something could be done.
I believe interleaving had been off succesfully for a period of time, but will have presumably been triggered back on an occasion when my router had been manually powered on/off numerous times, appearing as drop-outs.
Would appreciate assistance with this - Thanks.
5 REPLIES 5
imjolly
Message 2 of 6
Re: Interleaving Removal Enquiry
the mods will help change latency to fast and will post a contact us link
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
OlgaC
Moderator-Retired
Message 3 of 6
Hi chrissy_t,
Thanks for your post.
Please send me in your details using the "Contact The Mods" link found in my profile and I will be in touch to help.
Cheers,
OlgaC
chrissy_t
Message 4 of 6
Thanks for getting back in touch - have sent my details through the link as requested.
imjolly
Message 5 of 6
Can you update after mods get back in touch with you- good to see outcome
chrissy_t
Message 6 of 6
Yep - will do that.
