bpw88
Message 11 of 43
Re: Interleaving Troubles.. Stuck on 0.5 mbps.
Phones not working now however plugged into test socket... Wouldn't be acceptable to keep the phones off for 3+ days.. Any advice?
Message 12 of 43
you can connect a phone as well as the hub by connecting using a filter
bpw88
Message 13 of 43
And here it seems we're back to the original problem the engineer had. Old wiring causing a problem somewhere internally...
Message 14 of 43
you can use 2 filters which will enable all your extension sockets while allowing you to maintain your test socket connection
you need to connect to test socket to improve your connection until you can find the problem with your internal wiring.
you should also check your sockets and see if the bellwire is connected to terminal 3 and if so rmove it from all sockets
bellwire removal
bpw88
Message 15 of 43
Tried this. There are 2 phone extensions and 1 main phone that plug in at the front door. The direct phone is working but the extensions are not (kitchen and hands free phone)
However when all plugged into the main socket (not the test) everything works..
Message 16 of 43
sorry
if you connect to test socket then none of the extensions work?  the extensions should be connected to the back of the detached bottom half of the master and therefore won't work when you use test socket
Message 17 of 43
bpw88
Message 18 of 43
Hi thanks for the help! Sorry for the slow replies. Trying to keep up to date off my phone. Will post back soon after fiddling 🙂
Message 19 of 43
john46 easier to see than mine - shrunk mine to much lol
bpw88
Message 20 of 43
Ok cheers lads! Phones working and broadband also working. would you like updated router stats with everything plugged back in?
Good suggestion on the bell wires. Would it be worth ringing the house phone to see if it still drops?
Also, the router is normally plugged in away from the front door. What's the likelihood of these issues coming back if after 3-5 days there's an improvement and it goes back to its usual home?
