Message 21 of 43
Re: Interleaving Troubles.. Stuck on 0.5 mbps.
with all the changes then new stats would be helpful but you need to remain connected 24/7
bpw88
Message 22 of 43
Updated router stats:
ADSL Line Status
Connection information
Line state: Connected
Connection time: 0 day, 00:04:13
Downstream: 572 Kbps
Upstream: 444 Kbps
  ADSL settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.5 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 15.4 dB / 13.4 dB
Line attenuation (Down/Up): 21.0 dB / 12.3 dB
Output power (Down/Up): 0.0 dBm / 9.9 dBm
FEC Events (Down/Up): 2 / 0
CRC Events (Down/Up): 0 / 72
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
HEC Errors (Down/Up): 0 / 52
Error Seconds (Local/Remote): 0 / 5
  Hide Details
Message 23 of 43
providing you can get the internal wiring problems resolved every thing should be ok
Message 24 of 43
whatever has changed the stats are not as good - noise margin down to 15 instead of 30 and attenuaion up to 21 whereas it was down to 19
bpw88
Message 25 of 43
Obviously something going on with the wiring. Some of the sky boxes have got old micro filters so will try and get some new ones tomorrow.
Pulled the bellwires out. Which should hopefully help with the disconnects? And also the bellwires of the extensions. Will keep an eye on it over the next few days.
Thanks for the help!
Message 26 of 43
if there is any way that you can leave the rouet connected to master socket when found problem then you could get a filtered faceplate NTE2000 (adsl v 1.0) which you can fit and then there is no need to fit any other filters.  downside is broadband will only work in this new socket but does give better connection
bpw88
Message 27 of 43
Hey guys been watching it over the last 2 days and never managed to get more than 12 hours without a disconnect. Seems the bellwires have helped (disconnects seemed to be every 3-4 hours) but other than that the noise has gone way down..
Most recent stats:
ADSL Line Status
Connection time: 0 day, 05:43:52
Upstream: 444 Kbps
  ADSL settings
VPI/VCI: 0/38
Type: PPPoA
Noise margin (Down/Up): 6.5 dB / 3.6 dB
Line attenuation (Down/Up): 20.5 dB / 12.1 dB
FEC Events (Down/Up): 1400 / 0
CRC Events (Down/Up): 0 / 327
HEC Errors (Down/Up): 0 / 65
Error Seconds (Local/Remote): 0 / 315
  Hide Details
Bought some new filters today so will put the older skyboxes on those...
Message 28 of 43
are you connected to the test socket or somewhere else - just your  stats are not as good as those in post 12
bpw88
Message 29 of 43
Yes still connected to test socket. New filters introduced and gone up to:
Noise margin (Down/Up): 16.1 dB / 13.6 dB
Line attenuation (Down/Up): 21.0 dB / 12.2 dB
But just found out that phone calls still seem to disrupt the broadband. (hence the no longer than 12 hr connection) Even with bellwires / new filters 😞
Message 30 of 43
did you try the double filter idea that we posted?  if so and you phone using mobile does your broadband still drop conenction?  does conenction drop if you make calls?   if conenction still dropping when you receive calls even with double filter then that suggests a high resistence fault on your line and you need to contact the mods for assistance
contact mods
can take up to 3 working days for mods to contact you
