Friday
Message 1 of 10
Interleaving
Is there a way to check if BT are applying interleaving and also how much effect DLM is having on my line?
Cheers
9 REPLIES 9
legitimise_sailing
Distinguished Expert
Message 2 of 10
Re: Interleaving
You need a modem that will give your full line stats. The OR modem is usually locked and the HH5 gives only the bare minimum.
You can hazard a guess from the latency of your ping to the remote gateway.
To say thanks for a helpful answer, please click the white star
Friday
Message 3 of 10
Re: Interleaving
I have my huawei modem unlocked.  What stats should I be looking at? My ping on the bt speedtest is around 40-60ms
legitimise_sailing
Message 4 of 10
Re: Interleaving
If you use DSLstats, that will tell you in the bottom RH corner of the screen.
legitimise_sailing
Message 5 of 10
Re: Interleaving
Alternatively if you Telnet into the modem and issue the following command:
xdslcmd info --stats
You will see Interleaving depth given as 😧
😧 1 1 means depth 1, no interleaving.
Also there won't be any FECs counted.
Friday
Message 6 of 10
Re: Interleaving
Cheers mate,  Heres some stats I pulled from the modem
Stats recorded 22 Mar 2014 10:08:27
DSLAM/MSAN type: BDCM:0xa415 / v0xa415
Modem/router firmware: AnnexA version - A2pv6C030b.d22g
DSL mode: VDSL2
Status: Showtime
Uptime: 13 days 18 hours 4 min 19 sec
Downstream Upstream
Attenuation (dB):
Connection speed (kbps): 39999 9999
SNR margin (dB): 7.4 6.1
Power (dBm): 12.6 7.2
Interleave depth: 19 8
INP: 0 0
RSCorr/RS (%): 0.0028 0.5135
RSUnCorr/RS (%): 0.0011 0.0000
ES/hour: 12.1 0
I've a bit of reading to do so I can try to understand the info I'm getting
Friday
Message 7 of 10
Re: Interleaving
I'm a bit confused,  I've read on one forum that interleaving on downstream is 1-64 and upstream is 1-8 but I've also read posts on this forum of users claiming to have interleaving levels that are in the hundreds.
Can someone point me to a reliable source of information on this please.
boe323
Message 8 of 10
Re: Interleaving
your right ...my interleave depth is 1035 down and 1 up
Friday
Message 9 of 10
Re: Interleaving
Am I right in thinking that at only 19 the interleaving on my downstream is no concern but the amount applied to the upstream is at its max?
legitimise_sailing
Message 10 of 10
Re: Interleaving
Did you see this? http://www.kitz.co.uk/adsl/interleaving.htm
