Mersa
Message 1 of 7
Intermitent packet loss on wired connection only at weekends
The last 3 weekends i've been getting packet loss on my wired connections (tested via team speak and from CMD ping 8.8.8.8 and with some online games i play.(Wireless are working fine howeverl!)  I've been able to resolve it by turning the router off and leaving it off for 10 -15 minutes (unplugged)  (If it's less than that it doesn't seem to fix it).   I'd like if possible to find a solution to the problem other than me resetting my router (Sometimes 3 - 4 times a day at the weekends)  I never see the problem during the week however.
it's happening at this moment too
Addidtional info here:
1. Product name:BT Home Hub
2. Serial number:+068543+NQ50731094
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 30/06/15
4. Board version:BT Hub 5A
5. DSL uptime:13 days, 10:27:40
6. Data rate:19999 / 79906
7. Maximum data rate:25842 / 81188
8. Noise margin:15.3 / 7.1
9. Line attenuation:18.6 / 14.8
10. Signal attenuation:18.7 / 14.9
11. Data sent/received:2.0 GB / 30.5 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-SPQ9
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:BTHub5-SPQ9
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:44:e9:dd:7b:5b:48
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
23:42:44, 09 Apr.OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 217.42.38.52-​>31.13.90.1 on ppp3)
23:42:28, 09 Apr.IN: BLOCK [16] Remote administration (TCP [111.13.70.133]:15554-​>[217.42.38.52]:22 on ppp3)
23:42:26, 09 Apr.OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 217.42.38.52-​>31.13.90.1 on ppp3)
23:42:23, 09 Apr.BLOCKED 2 more packets (because of ICMP replay)
23:42:22, 09 Apr.OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 217.42.38.52-​>31.13.90.1 on ppp3)
23:40:50, 09 Apr.ath00: STA 00:e9:dd:7b:5b:4a IEEE 802.11: WiFi registration failed
23:40:40, 09 Apr.(1161166.150000) Admin login successful by 192.168.1.70 on HTTP
23:40:23, 09 Apr.(1161149.930000) Device disconnected: Hostname: Karen-​PC IP: 192.168.1.74 MAC: 94:fb:b2:5f:7b:cf
23:40:23, 09 Apr.(1161149.930000) Device disconnected: Hostname: tvae40ca8309b5 IP: 192.168.1.76 MAC: fc:f1:52:b4:cc:96
23:40:23, 09 Apr.(1161149.930000) Device disconnected: Hostname: KarenHaingsiMac IP: 192.168.1.67 MAC: 00:1e:52:7d:88:02
23:40:23, 09 Apr.(1161149.930000) Device disconnected: Hostname: kindle-​74dd3246c IP: 192.168.1.78 MAC: f0:27:2d:eb:5a:16
23:39:45, 09 Apr.OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 217.42.38.52-​>72.21.202.87 on ppp3)
23:36:57, 09 Apr.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 212.156.0.42-​>217.42.38.52 on ppp3)
23:32:34, 09 Apr.IN: BLOCK [16] Remote administration (TCP [81.27.85.28]:43464-​>[217.42.38.52]:22 on ppp3)
23:26:28, 09 Apr.BLOCKED 1 more packets (because of ICMP replay)
23:26:27, 09 Apr.OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 217.42.38.52-​>213.123.242.195 on ppp3)
23:26:11, 09 Apr.(1160297.950000) Port forwarding rule added via GUI. Service: World of Warcraft, protocol: TCP, external ports: any-​>6881-​6999, internal ports: 6881-​6999, internal client: Martins
23:26:11, 09 Apr.(1160297.950000) Port forwarding rule added via GUI. Service: World of Warcraft, protocol: TCP, external ports: any-​>6112, internal ports: 6112, internal client: Martins
23:26:11, 09 Apr.(1160297.950000) Port forwarding rule added via GUI. Service: World of Warcraft, protocol: TCP, external ports: any-​>3724, internal ports: 3724, internal client: Martins
23:24:37, 09 Apr.(1160203.400000) Device disconnected: Hostname: Karen-​PC IP: 192.168.1.74 MAC: 94:fb:b2:5f:7b:cf
23:24:37, 09 Apr.(1160203.400000) Device disconnected: Hostname: tvae40ca8309b5 IP: 192.168.1.76 MAC: fc:f1:52:b4:cc:96
23:24:37, 09 Apr.(1160203.400000) Device disconnected: Hostname: KarenHaingsiMac IP: 192.168.1.67 MAC: 00:1e:52:7d:88:02
23:24:37, 09 Apr.(1160203.400000) Device disconnected: Hostname: Unknown-​8c-​cd-​e8-​8a-​80-​5f-​2 IP: 192.168.1.73 MAC: 8c:cd:e8:8a:80:5f
23:24:32, 09 Apr.ath00: STA 8c:cd:e8:8a:80:5f IEEE 802.11: Client disassociated
23:23:32, 09 Apr.(1160138.410000) Device disconnected: Hostname: Karen-​PC IP: 192.168.1.74 MAC: 94:fb:b2:5f:7b:cf
23:23:32, 09 Apr.(1160138.410000) Device disconnected: Hostname: tvae40ca8309b5 IP: 192.168.1.76 MAC: fc:f1:52:b4:cc:96
23:23:32, 09 Apr.(1160138.410000) Device disconnected: Hostname: KarenHaingsiMac IP: 192.168.1.67 MAC: 00:1e:52:7d:88:02
23:23:31, 09 Apr.(1160137.740000) Lease for IP 192.168.1.73 renewed by host Unknown-​8c-​cd-​e8-​8a-​80-​5f-​2 (MAC 8c:cd:e8:8a:80:5f). Lease duration: 1440 min
23:23:31, 09 Apr.(1160137.740000) Device connected: Hostname: Unknown-​8c-​cd-​e8-​8a-​80-​5f-​2 IP: 192.168.1.73 MAC: 8c:cd:e8:8a:80:5f Lease time: 1440 min. Link rate: 42.9 Mbps
23:23:31, 09 Apr.(1160137.680000) Lease requested
23:23:29, 09 Apr.ath00: STA 8c:cd:e8:8a:80:5f IEEE 802.11: Client associated
23:23:00, 09 Apr.(1160106.270000) Admin login successful by 192.168.1.70 on HTTP
23:21:51, 09 Apr.(1160037.630000) New GUI session from IP 192.168.1.70
23:20:52, 09 Apr.(1159978.280000) Device disconnected: Hostname: Karen-​PC IP: 192.168.1.74 MAC: 94:fb:b2:5f:7b:cf
23:20:50, 09 Apr.ath00: STA 94:fb:b2:5f:7b:cf IEEE 802.11: Client disassociated
23:20:50, 09 Apr.ath00: STA 00:e9:dd:7b:5b:4a IEEE 802.11: WiFi registration failed
23:18:34, 09 Apr.OUT: BLOCK [7] ICMP replay (ICMP type 8 code 0 192.168.1.64-​>93.184.219.82 on ppp3)
23:18:14, 09 Apr.OUT: BLOCK [7] ICMP replay (ICMP type 8 code 0 192.168.1.64-​>105.16.187.3 on ppp3)
23:16:59, 09 Apr.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 54.232.229.64-​>217.42.38.52 on ppp3)
23:14:36, 09 Apr.OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.78]:51541-​>[31.13.90.36]:443 on ppp3)
6 REPLIES 6
john46
Message 2 of 7
Re: Intermitent packet loss on wired connection only at weekends
please post traceroutes to your games severs and one to bbc.co.uk for comparison
Mersa
Message 3 of 7
works fine for a min then falls over again. i've tried it on League of legends, WoW, FFXIV and Blade and soul,  effects can be seen when downloading files from any site or streaming from youtube etc where the speed drops to 0Kbps or the stream just stops for a moment.
FFXIV
Trace complete.
C:\Users\Martin>tracert 195.82.50.45
Tracing route to 195.82.50.45 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  BThomehub.home [192.168.1.254]
  2     *        *        *     Request timed out.
  3     *        *        *     Request timed out.
  4     *        7 ms     6 ms  31.55.187.180
  5     6 ms     7 ms     7 ms  core1-hu0-8-0-1.southbank.ukcore.bt.net [195.99.
127.176]
  6     *        7 ms     7 ms  core3-hu0-1-0-0.faraday.ukcore.bt.net [195.99.12
7.32]
  7     *        7 ms     6 ms  213.137.183.34
  8     7 ms     7 ms     8 ms  ldn-b3-link.telia.net [213.248.67.97]
  9     8 ms     8 ms     8 ms  ldn-bb3-link.telia.net [62.115.117.8]
 10    14 ms    14 ms    15 ms  prs-bb3-link.telia.net [62.115.134.94]
 11    87 ms   148 ms    24 ms  ffm-bb1-link.telia.net [62.115.112.125]
 12    24 ms    26 ms    25 ms  ffm-b10-link.telia.net [62.115.117.38]
 13     *       25 ms    25 ms  kddi-ic-301630-ffm-b10.c.telia.net [62.115.32.11
0]
 14    26 ms    25 ms    28 ms  195.82.60.29
 15    25 ms     *       25 ms  195.82.61.14
 16    25 ms    25 ms    25 ms  195.82.50.234
 17    26 ms    24 ms    25 ms  195.82.50.45
Trace complete.
Team speak
C:\Users\Martin>tracert 64.25.35.100
Tracing route to 64.25.35-100.ncsoft.com [64.25.35.100]
over a maximum of 30 hops:
  4     8 ms     8 ms     8 ms  31.55.187.176
  5    10 ms     9 ms     8 ms  core2-hu0-9-0-0.southbank.ukcore.bt.net [195.99.
127.172]
  6     8 ms     8 ms     *     195.99.127.70
  7     9 ms     9 ms     9 ms  213.137.183.102
  8     *        *        *     Request timed out.
  9     *        *        *     Request timed out.
 10     *        *        *     Request timed out.
 11     *      112 ms   125 ms  4.59.197.34
 12     *      117 ms   117 ms  64.25.35-100.ncsoft.com [64.25.35.100]
Trace complete.
Blade and soul
127.172]
Trace complete.
C:\Users\Martin>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.244.23]
  4     6 ms     *        6 ms  31.55.187.180
  5     *        *        8 ms  core2-hu0-19-0-1.southbank.ukcore.bt.net [195.99
.127.174]
  6     7 ms     6 ms     8 ms  peer2-et-10-1-0.telehouse.ukcore.bt.net [195.99.
127.7]
  7     7 ms     7 ms     *     194.74.65.42
 10     8 ms     8 ms     8 ms  ae0.er01.telhc.bbc.co.uk [132.185.254.109]
 11     8 ms     9 ms     8 ms  132.185.255.148
 12     8 ms     8 ms     8 ms  212.58.244.23
Trace complete.
.127.174]
127.7]
Trace complete.
john46
Message 4 of 7
all those traceroutes look fine
Mersa
Message 5 of 7
Yeh, it's intermitent, can't be fine for 5 mins then huge lag spikes and packet loss
running tests on http://www.dslreports.com/speedtest
and it's even giving me messages saying it couldn't complete due to packet loss. At abit of a loss
Seems it's settled back down to Outgoing packet loss running at about 6-10% on team speak again now
Mersa
Message 6 of 7
is there a longer version of Tracert? one that i could run over say 5 minutes, Or a ping command that repeats by default?
when pinging 8.8.8.8 It might be fine for a few minutes then go bad and get   2 or 3 request timed out then back to normal etc for a few minutes, so it's hard to actually pinpoint
Mersa
Message 7 of 7
not sure if this helps or not
 results from multiple runs here:
http://www.dslreports.com/tools/pingtest
Location	IP	Min	+PDV
NSW, AUS	54.153.204.70	298	+49ms
SP, Brazil	54.94.200.74	209	+36ms
ON, Canada	206.248.155.54	84	+15.8ms
QC, Canada	198.50.134.193	95	+695.8ms
Germany, EU	93.91.80.30	21	+26.2ms
Ireland, EU	54.154.207.39	20	+26.3ms
London, UK	88.80.191.58	8	+286.6ms
Tokyo, Japan	54.65.9.39	270	+64.2ms
Davao, Philippines	202.137.115.7	262	+81.4ms
San Juan, PR	209.91.216.173	137	+39.4ms
Singapore	54.169.160.227	254	+25.7ms
Taiwan	104.155.201.41	264	+119.8ms
CA, USA	64.140.161.58	171	+221.7ms
CO, USA	72.5.102.138	114	+40.9ms
DC, USA	65.79.226.210	87	+87.7ms
DE, USA	162.151.17.198	88	+41.5ms
GA, USA	24.72.224.10	97	+73.2ms
IA, USA	104.154.69.141	109	+82.8ms
IL, USA	162.248.92.123	93	+64.9ms
MI, USA	72.52.179.213	107	+36.1ms
NC, USA	192.254.79.130	101	+51.8ms
NY, USA	162.248.95.144	78	+1627.2ms
OR, USA	68.85.243.66	157	+59.3ms
SEA, USA	66.150.164.232	165	+36.9ms
TN, USA	63.135.176.24	103	+30.9ms
TX, USA	104.153.106.185	124	+31.4ms
NSW, AUS	54.153.204.70	294	+71.7ms
SP, Brazil	54.94.200.74	207	+30.7ms
ON, Canada	206.248.155.54	84	+60.9ms
QC, Canada	198.50.134.193	93	+30.8ms
Germany, EU	93.91.80.30	21	+54.9ms
Ireland, EU	54.154.207.39	20	+31.2ms
London, UK	88.80.191.58	8	+88.2ms
Tokyo, Japan	54.65.9.39	258	+98.1ms
Davao, Philippines	202.137.115.7	262	+50ms
San Juan, PR	209.91.216.173	143	+64.2ms
Singapore	54.169.160.227	256	+41.8ms
Taiwan	104.155.201.41	258	+64.5ms
CA, USA	64.140.161.58	176	+35.5ms
CO, USA	72.5.102.138	118	+214.1ms
DC, USA	65.79.226.210	85	+31.2ms
DE, USA	162.151.17.198	79	+59.2ms
GA, USA	24.72.224.10	98	+25.7ms
IA, USA	104.154.69.141	109	+22ms
IL, USA	162.248.92.123	93	+31.1ms
MI, USA	72.52.179.213	107	+68.7ms
NC, USA	192.254.79.130	98	+233.6ms
NY, USA	162.248.95.144	79	+41.2ms
OR, USA	68.85.243.66	166	+43.9ms
SEA, USA	66.150.164.232	169	+31.2ms
TN, USA	63.135.176.24	100	+40.8ms
TX, USA	104.153.106.185	114	+60.4ms
NSW, AUS	54.153.204.70	306	+73.7ms
SP, Brazil	54.94.200.74	206	+26.6ms
ON, Canada	206.248.155.54	85	+26.4ms
QC, Canada	198.50.134.193	95	+26.7ms
Germany, EU	93.91.80.30	20	+64.5ms
Ireland, EU	54.154.207.39	20	+41.7ms
London, UK	88.80.191.58	7	+150.4ms
Tokyo, Japan	54.65.9.39	260	+55.9ms
Davao, Philippines	202.137.115.7	258	+114.7ms
San Juan, PR	209.91.216.173	140	+67.9ms
Singapore	54.169.160.227	265	+51ms
Taiwan	104.155.201.41	257	+170.3ms
CA, USA	64.140.161.58	157	+31.7ms
CO, USA	72.5.102.138	119	+1175.7ms
DC, USA	65.79.226.210	88	+212.8ms
DE, USA	162.151.17.198	78	+78.2ms
GA, USA	24.72.224.10	100	+32.4ms
IA, USA	104.154.69.141	109	+140.7ms
IL, USA	162.248.92.123	94	+55.8ms
MI, USA	72.52.179.213	103	+59.5ms
NC, USA	192.254.79.130	100	+54.1ms
NY, USA	162.248.95.144	77	+83.3ms
OR, USA	68.85.243.66	166	+59.1ms
SEA, USA	66.150.164.232	169	+36.1ms
TN, USA	63.135.176.24	103	+247.3ms
TX, USA	104.153.106.185	119	+35.8ms
