keneu
Message 11 of 16
Re: Intermittent Packet Loss (Resulting in large lag spikes when gaming)
Sorry for the delay, have been busy.
From what I can see there is no test socket on this line. This house has 2 phone lines, the phone line which I'm trying to sort out is in a room which was "redone" when we moved in - it used to be a garage and then we turned it into a bedroom with a phone line. This phone line only has 1 wall socket and I just took the faceplate off and all that's behind it is a hole in the wall with some wires leading to the faceplate.
Any further ideas?
Message 12 of 16
you say you have two lines are they both broadband activated
keneu
Message 13 of 16
Yeah both have lines broadband provided by BT - separate phone numbers and account for each one
Message 14 of 16
do both lines have the same problem ?
keneu
Message 15 of 16
I hooked up my PC to the other phone line in the house and it's a lot smoother. Think I got 1 lag spike that was "my end" during maybe 4-5 hours of gaming over the last couple of days. I remembered though that the other phone line isn't on BT though, it was changed to Sky recently and I completely forgot. I'll amend previous posts as appropriate. It seems I can't edit my other posts.. this could get messy to keep track of.
So this basically suggests it's something to do with my phone line's setup. Is it possible that it's a router issue rather than a service issue? I don't have another router to test it, any ideas how I could test if it's the line or the router or something else?
Message 16 of 16
maybe you could try and borrow one from a friend or neighbour
