MelRob
Message 1 of 15
Intermittent Packet Loss
Hi,
I've just attempted to use the online chat function to talk to a technical support but after 30 odd mins, it then cancelled as I finally got to number 1 in the queue, typical.
I have a problem - best illustrated if I continually ping a website, such as www.google.co.uk -t, I get roughly 10 seconds of good connection, and then 2-3 seconds of lost packets/Request time outs.  Please see below an example:
Reply from 209.85.169.105: bytes=32 time=40ms TTL=48
Request timed out.
Request timed out.
Reply from 209.85.169.105: bytes=32 time=47ms TTL=48
Reply from 209.85.169.105: bytes=32 time=41ms TTL=48
Reply from 209.85.169.105: bytes=32 time=42ms TTL=48
Reply from 209.85.169.105: bytes=32 time=43ms TTL=48
Reply from 209.85.169.105: bytes=32 time=73ms TTL=48
Reply from 209.85.169.105: bytes=32 time=39ms TTL=48
Request timed out.
Reply from 209.85.169.105: bytes=32 time=50ms TTL=48
Reply from 209.85.169.105: bytes=32 time=45ms TTL=48
Reply from 209.85.169.105: bytes=32 time=44ms TTL=48
Request timed out.
And this continues in a never ending cycle - Any chance you could help??
I'm even struggling to have a stable enough connection to load a speedtest right now.
14 REPLIES 14
gouledw
Recognised Expert
Message 2 of 15
Re: Intermittent Packet Loss
Hello :),
Can you please post your ADSL stats by following this direct link; http://192.168.1.254/index.cgi?active_page=9116 << it only works if you have a Home Hub 2.0+ and remember to type your password in!
Also we need a speedtest just to have a look and make sure everything's okay? Use this link http://bit.ly/o8qqQ9 as it will also help you diagnose and give you a list of solutions afterwards to help you diagnose your problems if it thinks there is a problem. Could you please also copy and paste the results from the White/Black/Green pop out page including your IP profile, DSL Connection Rate and speed achieved during test.
Run a line test to determine if or not it is an external problem: http://bit.ly/tgwip
Can you also confirm if you're connected at the master socket or an extension? And what your type your master socket is according to this picture
Lastly for now, call 17070 and Press Option 2 for the Quiet Line test and where possible use a corded phone as DECT handsets can pick up electrical interference?
Are you connected wired or wirelessly?
MelRob
Message 3 of 15
Hi! I tried that link and it didn't work - but found my ADSL settings
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 1:23:06
Downstream4,128 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)21.5 dB / 8.0 dB
Line attenuation (Down/Up)13.0 dB / 6.5 dB
Output power (Down/Up)15.8 dBm / 12.3 dBm
Loss of Framing (Local)0
Loss of Signal (Local)1291
Loss of Power (Local)0
FEC Errors (Down/Up)1707058 / 4380
CRC Errors (Down/Up)98201 / N/A
HEC Errors (Down/Up)N/A / 2715
Error Seconds (Local)3
Speed test results: 4.1mbps, estimated 8.0mbs
Speed doesn't appear to be the problem at all though, it's just the continuous interrupts!
It looks like a Non NTE5 to me and yes I'm connected via the master socket - I have been testing via a cable.
I can't test the line at the moment as I'm connected to the internet and have no other means of accessing the linechecker facility!
Message 4 of 15
Hi could you repost the full bt speed test please including the ip profile http://speedtester.bt.com/
or http://bt.custhelp.com/app/answers/detail/a_id/9354/c/346,4740,5520
gouledw
Recognised Expert
Message 5 of 15
Don't worry about being connected to the internet, it doesn't knock you off or have any effect on the result.
Can you also run a test at http://www.pingtest.net
MelRob
Message 6 of 15
Pingtest:
http://www.pingtest.net/result/49366097.png
That seems to imply it's not packet loss, just hiccups of lags every 10 seconds??
Line check:
Results of line test
We cannot detect a problem with this line.
It may be caused by a faulty phone or equipment.
Annnd speedtest
Results Image not loaded
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
 Download  Speed
 1163 Kbps
0 Kbps7150 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 1163 Kbps
 For your connection, the acceptable range of speeds is 600-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :4544 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 3000 Kbps
2. Assured Rate Test: -provides background information.
 Download Speed
 2572 Kbps
0 Kbps600 Kbps
 Download speedachieved during the test was - 2572 Kbps
 For your connection, the acceptable range of speeds is 576-600 Kbps.
 Assured Rate IP profile on your line is - 600 Kbps
Well, none of those results were quite as dramatic as I was hoping for to emphasise how frustrating these hiccups are, here's a screenshot of my pinging results for a while last night if the helps - red = Request timed out.
http://imageshack.us/photo/my-images/3/pinging.jpg/
Any thoughts? Smiley Sad
Gigabit
Message 7 of 15
Hello,
Your sync speed is very low for your attentuation and your SNR margin is incredibly high. Are you connected to an extension?
Gigabit
Message 8 of 15
I looked again and you're not connected to an extension. The best option would be to get BT to install a new socket. I believe that BT will fit one for free if you get an engineer round. It will give you the best speed possible.
You should be syncing at 8128kbps and getting around 6-6.6Mb/s downloads on your connection.
MelRob
Message 9 of 15
Well, whilst that may be possible - this has suddenly come on from nowhere, so I'm hoping there's got to be something else that is the cause?
Gigabit
Message 10 of 15
Does the problem happen all the time or only at certain times of the day?
