MelRob
Message 11 of 15
Re: Intermittent Packet Loss
All day - This hasn't been a problem until the last week or so
Gigabit
Message 12 of 15
Have you contacted the MODs? They should be able to help.
Message 13 of 15
arobertson545 on a short line that the poster has spare noise margin that is is a good thing
Message 14 of 15
arobertson545 if there is no voice line fault Openreach will charge 130.00 to install a new master not good advice
Message 15 of 15
melrob you could try connecting your hub to the test socket at the rear of removable lower front plate of the master socket that will remove any internal wiring from the system and connect you directly to the exchange try that and see if the disconnects stop
