gedh
Message 1 of 1
Intermittent frequent disconnections and phone call disconnects broadband
Grateful for help: I have a Home Hub 5 and Inifinity 2. Master socket with separate broadband socket above phone socket and no extensions
While doing a quiet line test following frequent disconnections I noticed a crackle and that putting the phone down caused the boradband to disconnect. Don't normally use the phone. Therefore raised a log and an engineer called. They did an "extensive test" at the master socket but found no fault. At that time the phone did not disconnect the broadband either. I said there must be a reason for the disconnects so they did a test at the connection on the exterior wall and then a test again at the master socket. Then they said they could see lots of "forward errors" so concluded the issue was with the cable from the exterior wall to the master socket. This cable has now been replaced. The connecction was then stable for a couple of days at 35 Mbps but now drops frequently again a phone call disconnects broadband. This might be when the speed is low (8 to 9 Mbps). after a phone call the connection is usually a higher speed e.g 32 to 35 Mbps.
event log:
13:49:07, 20 Jun.(133525.800000) WAN operating mode is VDSL
13:49:07, 20 Jun.(133525.800000) Last WAN operating mode was VDSL
13:49:06, 20 Jun.(133524.420000) PPP IPCP Receive Configuration ACK
13:49:05, 20 Jun.(133524.420000) PPP IPCP Send Configuration Request
13:49:05, 20 Jun.(133524.410000) PPP IPCP Receive Configuration NAK
13:49:05, 20 Jun.(133524.410000) PPP IPCP Send Configuration ACK
13:49:05, 20 Jun.(133524.410000) PPP IPCP Receive Configuration Request
13:49:05, 20 Jun.(133524.400000) PPP IPCP Send Configuration Request
13:49:04, 20 Jun.(133523.190000) PPPoE is up -​ Down Rate=10405000Kbps, Up Rate=1606000Kbps; SNR Margin Down=6.4dB, Up=7.7dB
13:49:04, 20 Jun.(133523.180000) CHAP authentication successful
13:49:04, 20 Jun.(133523.130000) CHAP Receive Challenge
13:49:04, 20 Jun.(133523.130000) Starting CHAP authentication with peer
13:49:04, 20 Jun.(133523.130000) PPP LCP Receive Configuration ACK
13:49:04, 20 Jun.(133523.120000) PPP LCP Send Configuration Request
13:49:04, 20 Jun.(133523.120000) PPP LCP Receive Configuration Reject
13:49:04, 20 Jun.(133523.120000) PPP LCP Send Configuration ACK
13:49:04, 20 Jun.(133523.120000) PPP LCP Receive Configuration Request
13:48:14, 20 Jun.(133472.740000) PTM over DSL is up
13:47:43, 20 Jun.(133442.210000) PTM over DSL is down after 336 minutes uptime
13:47:43, 20 Jun.(133442.190000) PPPoE is down after 335 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
13:47:38, 20 Jun.(133436.930000) PPP LCP Send Termination Request [User request]
08:11:57, 20 Jun.(113295.500000) WAN operating mode is VDSL
08:11:57, 20 Jun.(113295.500000) Last WAN operating mode was VDSL
08:11:55, 20 Jun.(113294.120000) PPP IPCP Receive Configuration ACK
08:11:55, 20 Jun.(113294.120000) PPP IPCP Send Configuration Request
08:11:55, 20 Jun.(113294.110000) PPP IPCP Receive Configuration NAK
08:11:55, 20 Jun.(113294.110000) PPP IPCP Send Configuration ACK
08:11:55, 20 Jun.(113294.110000) PPP IPCP Receive Configuration Request
08:11:55, 20 Jun.(113294.110000) PPP IPCP Send Configuration Request
08:11:54, 20 Jun.(113292.900000) PPPoE is up -​ Down Rate=34956000Kbps, Up Rate=6744000Kbps; SNR Margin Down=6.0dB, Up=6.1dB
08:11:54, 20 Jun.(113292.880000) CHAP authentication successful
08:11:54, 20 Jun.(113292.830000) CHAP Receive Challenge
08:11:54, 20 Jun.(113292.830000) Starting CHAP authentication with peer
08:11:54, 20 Jun.(113292.830000) PPP LCP Receive Configuration ACK
08:11:54, 20 Jun.(113292.820000) PPP LCP Send Configuration Request
08:11:54, 20 Jun.(113292.820000) PPP LCP Receive Configuration Reject
08:11:54, 20 Jun.(113292.820000) PPP LCP Send Configuration ACK
08:11:54, 20 Jun.(113292.820000) PPP LCP Receive Configuration Request
08:11:04, 20 Jun.(113242.560000) PTM over DSL is up
08:10:30, 20 Jun.(113208.730000) PTM over DSL is down after 94 minutes uptime
08:10:30, 20 Jun.(113208.730000) PPPoE is down after 93 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
08:10:25, 20 Jun.(113203.540000) PPP LCP Send Termination Request [User request]
06:36:31, 20 Jun.(107569.590000) WAN operating mode is VDSL
06:36:31, 20 Jun.(107569.590000) Last WAN operating mode was VDSL
06:36:29, 20 Jun.(107568.210000) PPP IPCP Receive Configuration ACK
06:36:29, 20 Jun.(107568.200000) PPP IPCP Send Configuration Request
06:36:29, 20 Jun.(107568.200000) PPP IPCP Receive Configuration NAK
06:36:29, 20 Jun.(107568.200000) PPP IPCP Send Configuration ACK
06:36:29, 20 Jun.(107568.200000) PPP IPCP Receive Configuration Request
06:36:29, 20 Jun.(107568.190000) PPP IPCP Send Configuration Request
06:36:28, 20 Jun.(107566.970000) PPPoE is up -​ Down Rate=34958000Kbps, Up Rate=7110000Kbps; SNR Margin Down=8.1dB, Up=6.2dB
06:36:28, 20 Jun.(107566.960000) CHAP authentication successful
06:36:28, 20 Jun.(107566.900000) CHAP Receive Challenge
06:36:28, 20 Jun.(107566.900000) Starting CHAP authentication with peer
06:36:28, 20 Jun.(107566.900000) PPP LCP Receive Configuration ACK
06:36:28, 20 Jun.(107566.900000) PPP LCP Send Configuration Request
06:36:28, 20 Jun.(107566.900000) PPP LCP Receive Configuration Reject
06:36:28, 20 Jun.(107566.890000) PPP LCP Send Configuration ACK
06:36:28, 20 Jun.(107566.890000) PPP LCP Receive Configuration Request
06:36:28, 20 Jun.(107566.890000) PPP LCP Send Configuration Request
06:35:38, 20 Jun.(107516.720000) PTM over DSL is up
06:35:04, 20 Jun.(107483.390000) PTM over DSL is down after 177 minutes uptime
06:35:04, 20 Jun.(107483.390000) PPPoE is down after 177 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
